Question about Magic Chef CAV4000AWW Top Load Washer
I have an old top load Magic Chef washing machine. I noticed that clothes have been coming out very wet lately and I have been re-running the spin cycle. Today when I tried to re-run it, I noticed that it didn't seem to spin so I started experimenting with it. It sometimes spins, sometimes doesn't, there doesn't seem to be a pattern. When I turn it manually clockwise, it gets stuck after about quarter of a circle, counter clock wise it seems to manually turn. Any ideas would be appreciated! Thanks in advance!
  • 26 Answers
First thing to check is the belt it is normal for it to not turn in both directions. There is a brake.
Posted on Apr 30, 2010
The machine wash but the spin not working. so the cloth stay wet
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Magic Chef CAV2000AWW Top Load Washer
I have a magic chef 20 lb capacity heavy duty washer model W20HN3S serial ME851474 with spin problems. Clothes come out soaking wet. Can I replace a belt?
If your washer will wash (agitate) your clothes but does not spin well, you will need to replace the "thrust bearing" in the washer. The repair is simple and will only take you a short to do. Here is a link to the "thrust bearing kit" you will need.
Jan 07, 2011 | Chef Cooking Magic Chef Washing Machine...
Doesn't spin clothes dry enough
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 21, 2010 | Kenmore 22422 Top Load Washer
MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
Feb 02, 2010 | Magic Chef CAV4000AWW Top Load Washer
My washing machine drains but does not spin
Look for a motor belt that is worn out and make sure that the drum turns freely (machine off).
Aug 01, 2009 | Magic Chef CAV2000AWW Top Load Washer
Water problem
Apr 01, 2009 | Washing Machines
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Feb 11, 2009 | Magic Chef CAV4000AWW Top Load Washer
MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
Aug 31, 2008 | Magic Chef CAV2000 Top Load Washer
Itis a 'no spin".
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Oct 18, 2006 | Magic Chef CAV2000 Top Load Washer
Itis a 'no spin".It washes, drains, then it rinses, bypass spin to off.
Magic Chef CAV4000AWW Top Load Washer Logo
299 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
