I replaced the power supply, (after the previous one was blinking)plus I added RAM to the computer at the same time. I powered it up and the yellow light came on under the power button. The computer worked great. Started up and ran fast. I shut it all down, waited a few minutes and tried to power it up again to see if the yellow llight went out. No dice. The power button light did not come on (normally blue), not even in yellow. Any suggestions?
  • 6 more comments
  • swederag Apr 30, 2010
    What would cause the pellow light to come on?
    Didn't believe answer was complete
    I replaced the new RAM with the original Ram and still no go. Any ideas?
    did not answer problem?
    this is not a laptop. There is no battery. I replaced the power supply unit. It has a solid green light. I hit the power button now and nothing happens. Previously at the first startup after I replaced the power supply and the RAM, the little light located under the front turn on switch was yellow and is usually blue. After I shut the unit down I waited and then restarted to see if the blue light would come on. Nothing happened, but the green light came on at the power supply on the back of the unit.
    Please help.
    Hi and thanks. The computer did operate just fine after the equipment was replaced. The little yellow light came on when it was running. After I shut it down, it would not start again. Do you believe that your suggestion will work?
    I tried what you recommended and no dice. No signs of life except the green light on the power supply is on solid.
    Could you tell me where this battery is located on this unit please? I am unable to find it.
  • 781 Answers
We need more info
provide brand name and model, info on your motherboard if possible and the amount, capacity of old (if your going to use it in your new system) and new memory sticks.
where there any beeps when you started the computer up? or it just seems dead?, if dead recheck power supply is working (possibly in another system) and re-check that old the connectors are properly seated
did you take any ESD preventive measure when you opened your computer to replaced the power supply and the memory sticks (ESD is Electro-Static Discharge, if you didn't it's possibly that inavertenly something may have been demaged beyond repair even if you did not see any sparks)
note: when you do troubleshooting or upgrades remember to do one at a time otherwise the results are not the ones expected as you can now see. :)
now..
I would say try to go back to the previous memory configuration, (hopefully you still have the memory stick(s) that you had before you started) and try to power your system now that you have a brand new power supply. test the computer to see if that gets it to work again, leave it on for a while, go online.. do whatever for a couple of hours.
now. shut down the computer and proceed to upgrade your memory, it's very important that you are sure that the memory you bought is the memory supported for your system (in some cases I have encounter that incorrect memory can work for a while before it starts acting up!. it's usually recommended not to mix old and new memory sticks so depending on what sticks and the number of them try to change 1 thing at time and proceed to test.
post back with your findings and the answers as they will help us assist you better!
Posted on Apr 30, 2010
  • 1,472 Answers
Swederag
It is possible that your old powersupply damaged your motherboard. Another thing that could be an issue is the power may not be charging the capacitors properly.
To address this unplug the AC power from the power supply and hold down the power button for 60 seconds. This will clear the power on the system. Next plug the power back and try to turn on the system.
Another thing to look at is did you get the same wattage or higher on the new power supply because the new one may be under powered
Let me know how things go
Issken
http://www.fixya.com/users/issken
  • Will Hartford
    Will Hartford Apr 30, 2010
    swederag
    Then if the power supply is not under powered then most likely there is something wrong with the motherboard. Note it is possible that there is something wrong with the replacement powersupply. So you might try another one but another one has the same problem then it is the motherboard that it having issues.
    Issken
    President:
  • 1,851 Answers
Remove the power cord, remove the battery again, and try some times to power the system up (just for the power supply to discharge). After some minutes put the battery back and the power cord. At the first start up of the machine enter the bios and load setup defaults, save it and restart. Load bios again and make any changes you like (date, time, boot order e.t.c.) Save and finish.
In case of a problem or clarification, don't hesitate to post me a reply.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
  • Stelios
    Stelios Apr 30, 2010
    Of course it's not a laptop, it's a desktop. I asked you to eject the battery that keeps the bios settings and reset these settings since sometimes after a change at the power supply there are at a mess. About the battery : Loacate a small round metal that looks like this
    Eject it and follow the procedure that I told at my previous post.
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
  • Stelios
    You have to open the case and locate the motherboard. The battery is on the motherboard. If you know the model of your motherboard, post it to me and I'll send you the exactly location.
    If you are satisfied, rate my solution with the "flags".
    Thanks and regards
    Stelios
  • 10,865 Answers
Hello Swederag. Almost got it but no cigar : ^ )... The RAM you got is not compatible with your computer. Get RAM tha sis compatible and you should be aok. Joe
    President:
  • 803 Answers
If the computer is running fine then i would say just leave it alone if its not working check all the connections and make sure that the ram and cpu are seated properly just make sure all the wires are where they are supposed to be and you should be just fine
Blinking amber power button light on Optiplex 990
It seems you have a problem with your Processor regulator that is why your computer sending an amber message.
This problem always happens to Dell Optiplex mostly and there is no solution for this except replacing your Motherboard.
To verify this problem unplug yellow (2 yellow and 2 black cables) cables near the processor and then try to turn it on when you see the fan processor can run smoothly and the power light getting green that is the sign that your processor regulator having some sort of problem.
Hope this will answer your problem
Apr 30, 2012 | Dell OptiPlex 990 SFF 1 x Core i7 2600 34...
Hard drive will not turn on. Green light in back is blinking. But will eventually die out if disconnected from power supply. Happened when we moved it from one room to another. We know it isn't the...
Discconect the computer from the power outlet. Open the case, take the RAM out of the slot. Wait 15sec, reinsert the RAM, Now try to restart the computer. If this does not work, my guess is that the power supply is malfunctioning. And it needs to be replaced.
Mar 08, 2011 | HP Hewlett Packard Pavilion A6200N PC...
Dell 8200 Dimension shuts down on bootup. Making
The clinking sound could well be your drive heads snapping back into parking location if your power supply is going out. Since the 8200 comes with a pretty weak power supply those tend to go out shortly after you've upgraded to a better graphics card or added another drive to the system. I've replaced mine a few times and now have a 450 watt supply in it which seems to be able to handle a powered video card and the 2nd HD, 2nd dvd without running out of juice.
Another good thing for these old dimensions is the addition of a case /slot fan to help with cooling a bit more. (see included picture)
I've had dealings with a number of dimensions from this era not cooling enough and the slot fans really helped stability.5a04930.gif
Let me know if any of this helps your situation.
Jan 24, 2010 | Dell Dimension 8200 PC Desktop
Dell Insp 4600C blinking yellow power light
the issue could be woth the power supply unit or internal wirings ..
Jul 19, 2009 | Dell Dimension 4600C PC Desktop
New ower supply but computer still no comming on
sounds like a burnt motherboard to me. Replace with similar MB that has same socket for processor and same slots for RAM. A decent MB will run you about $40-70 as long as it isn't a gaming system or something.
Jul 03, 2009 | Medion M3 Composer 5100 PC Desktop
My e machine is blinking a yellow light.
Sounds to me like the power supply is bad cause its not providing the right voltages which is why the computer can't turn on.
Try a different known good working power supply. If it turns on then your original power supply is bad. If you still get a blinking yellow light then that means the motherboard is bad for sure and would need to be replaced.
Jun 02, 2009 | Computers & Internet
Compaq 6458cl. Just changed DVD drive and added 1gb memory . Will not power on. Push and holding on/off buttom causes the green and yellow LEDS on the button to blink. Also both fans will run while bu
Most likely your motherboard does not like the ram you installed.. remove one or both of the ram chips leaving the one that was in originally.. test with that chip .. if it works something is wrong with the new ram: it's either the wrong speed or voltage for your motherboard or possibly defective.. you can consult your motherboard manual or motherboard manufacturers site for a complete list of approved RAM.
Keep in mind, most gaming memory requires a higher voltage than generic memory and some motherboards just dont produce it..
Apr 19, 2009 | Computers & Internet
Flashing Green Light on Power BESTEC Power Supply
Hi. NO, *********** board is not fried. I am not sure what the problem is but I do know how to fix it. It is usually casued by power outages (even if you have UPS supply).
1. TAKE OUT THE ELECTRICITY LEAD TO THE COMPUTER. Look inside the computer and find the bunch of wires coming from the power supply unit (the box thing at the top with the fan and all those colouted wires!).
2. Find where these wires run into a plastic connector and plug into the mother board. Unplug it.
3. Now plug the electicity lead back into the computer. The light should now stay ON.
4. Plug in the connector again... and boot up. Leave it run a while to convince it!
5. Repeat this process if it does not work first time.
This should fix your problem . It works for me when I get this problem.
Friend in Spain
Jan 10, 2009 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
My Moniter Is Blank
First make sure that you have the P4 connector (the square one at the top of the board connected to your P4 power from the power supply.
From here I would disconnect the data cables from the hdd, optical drives, and remove all video/peripheral cards. You should have only the RAM, CPU, and power connected, then try to boot again.
If this works, then add 1 device at a time until it fails to start. This will isolate the component that is giving you problems.
With a single stick of RAM, try to get the computer to POST. (if possible, test the ram in another machine first to ensure that RAM is good)
Jan 01, 2009 | ASUS EN8400GS SILENT/HTP/256M PCI-E TV-OUT...
Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Mar 06, 2008 | Dell Dimension™ 4600C PC Desktop
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
