Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
H232R weed trimer won`t start no spark new coil
  • 64 Answers
Make sure the shut off switc isn't shorting out and the flywheel may not have enough magnetism in it to create a charge in th coil.
Posted on May 01, 2010
Swisher E4 (lack of power and rpm) ???
Hi Davis:
Check exhaust/muffler. Make sure it is not obstructed with carbon.
Check trimmer string is not too long.
Check air filter. Make sure it's clean
What is history? Was it running well and then something specific happened?
Spark plug - how long since it's been changed?
Hope this helps.
May 01, 2015 | Swisher E4 Shindaiwa 245cc Commercial...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
Lawn trimer repair shops surrey/delta ..c.
Carb switch coil gas,gas lined primer bulb spark plug. Start with carb cleaner in the intake. If it starts move to carb.
Mar 09, 2013 | Toro 15" Electric Trimmer&Edger
Gas weed trimer will not stay running/clean gas lines/new fuel gas fillter/new gas/oil
Try checking the sparkplug wire. They sometimes get loose and don't make good contact. Clean the contact, if it is corroded, clean with a wire brush. The Spark plug may need to be replaced, be sure a new spark plug has the right gap size (you can adjust that yourself). Beyond that, I would take it in for servicing.
If it still does not keep running, check for leaking lines. If there are air leaks around the carborator, it will run rough and not for long. Hope that helps.
May 02, 2012 | Garden
How to proceed starting a homelite weed trimer for the first time in over eight years.
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, @@
Dec 31, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
I have a craftsman 32cc weedwhacker trimmer and its brand new and it hasnt started from day one it isnt getting any spark at all
If you have spark problems, remove the wire and then remove the plug, reattach the wire and ground the plug to the engine and pull the string, you should see arc and hear it pop, if not, take the plug to another piece of equipment and remove that equipment's plug wire and attach it to the plug from the weed ******* and then ground it and test it. If still no spark, then plug bad, if plug then the weed ******* has a problem with the spark plug wire or the ignition coil.
If you have spark at first test, then the problem with the weed ******* is somewhere else.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
String-trimmer (weed eater) won't start.
the only thing left is the coil that is inside the cover right next to the flywheel with a gap of 10 thousand of a inch a business card will work but a new coil is almost thr price of a new trimmer unless you have a used one
Nov 05, 2009 | Garden
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
148 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
