Question about Kenmore Elite Oasis 27052 Top Load Washer
How to remove casing from kenmore elite top loader screws are in the rear of washer
  • 299 Answers
Here's a link to a video on opening a Whirlpool Cabrio which is the same as the Oasis which is just a Sears branded version of the same washer.
http://s160.photobucket.com/albums/t200/Zenzoidman/Washers/?action=view&current=cabrio-fixitnow.flv
Posted on Apr 30, 2010
How do i disassemble a kenmore elite washer to get to the water pump
In a typical Kenmore top loader, screws are removed from the boittom of the control panel, allowing the panel to be rotated up toward the rear of the unit. This reveals two spring latches. Some dispenser tubing may have to be disconnected prior to removing the cabinet. The two spring latches, when released, allow the cabinet to be slid forward to expose the inner assemblies. The pump is located in the lower front.
May 09, 2014 | Kenmore 24032\24036 Top Load Washer
How do you open the top on a kenmore elite washer to access the tube.
on a top loader the controls are flipped up then the cabinet gets removedthemobilian_2256.jpg
front loader yall remove screws from the back and lift the top off
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 30, 2011 | Kenmore Washing Machines
Kenmore elite oasis top loader 27062
See the following Whirlpool / Kenmore service manual for the Whirlpool Cabrio washer. The Kenmore Oasis is basically the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Also see the Sears Parts site for your washer.
Enter the full (###.########) model number and you should see descriptions of the major components and parts lists.
May 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
DOES ANYONE KNOW WHERE i GET GET INSTRUCTIONS ON REPLACEING THE PRESSURE SWITCH ON MY KENMORE WASHER
If this is a FRONT LOADER, just follow these simple steps:
1. UNPLUG the washer.
2. Remove the top panel of the washer by locating and removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off.
3. The pressure switch is located on the right hand side rear of the washer (as viewed from the front). Disconnect the connector plug and air hose.
4. Remove the mounting screw (if equipped). Some of this switches simply clip in place.
If this is a TOP LOADER, the pressure switch will be located inside the operator console behind the load level selector knob. Some of these consoles have a removeable back, others you have to lift up for access.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Mar 01, 2010 | Kenmore Elite 45986 Front Load Washer
Where can I find the model number on my kenmore elite washer?
TOP LOADERS
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
FRONT LOADERS
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Oct 26, 2009 | Kenmore Washing Machines
Kenmore elite he3t steam front loader - 110.4674-2 --- f35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite top loader how do I get the case off?
Hi, Get me a model # and I can assist you with fixing this issue.
Vic
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Font loader washer water does'nt shut off
remove top replace fill valve left rear be sure not to remove the screens inside valve except to clean but be sure to reinstall or trash may get into valve and not allow proper shutoff
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
Removing cabinet of kenmore elite washing machine
It would help if I had your model number, but I'm assuming you have a Kenmore top loader that has the fill hoses attached under the left rear of the washer casing. With the brass clips removed, you should be able to move the cabinet off the frame slightly to give you enough room to reach your hand under the wash tub rim and disconnect the hoses. You may need a set of pliers to remove the hose clamps. I hope this helps you.
If you are having difficulty, please post back and let me know.
Was there a reason why you were removing the cabinet? Do you need further assistance?
May 23, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis 27052 Top Load Washer Logo
254 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
