Question about Dean Dimeblade Tribute Electric Guitar
Broke the v bridge on my dimeblade, anyone know where I can get a replacement?
  • 10,865 Answers
Hello. Go to this link which is the homepage of Dean guitars. There you will find the email address to send them a note and get the new v bridge Joe
http://www.deanguitars.com/dean_winter_06/dimeblade.htm
Posted on Apr 30, 2010
Accident broke one of the plastic brackets that hold the aluminum bars on my Yamaha DTXpress III drum kit. Does anyone know how to get a replacement? Parts are not listed in the owners manual.
It is possible to order spares for most Yamaha instruments.
If you can let me know what part I can check availability for you.
Circle the broken part and email back to me.
Dan
admin@beckettsmusic.co.uk
Jan 25, 2013 | Yamaha Music
How do I wire up my 4subs in bridged to my peace 2600
Please state the subs impedance, but assuming 4 subs with 8Ohm Voice Coil you CAN'T run them in parallel in Bridge Mono because this amp's minimum impedance is 4Ohm in bridge and 2Ohm stereo, maybe a series/parallel connection work, but what's the advantage to run them in Bridge mode? This amp delivers 900W per channel at 4Ohm, you can run a pair paralleled for each channel in a safe way and without the high-risk of your amp being destroyed, besides, amp power at 4Ohm Bridged is NOT recommended for continuous use, let me know your results...
May 13, 2012 | Peavey Pv 2600 Power Amplifier
Yamaha pt300. was working fine. Now only makes loud humming noise which doesn't repsond to change in volume. Monitor display shows keys register as being played, but no sound can be heard except loud...
Likely the power adapter has failed if it uses one. Try a new one first.
If half the rectifier blows out, a very impure DC voltage is applied which will be heard in the audio output.
Sep 27, 2009 | Dean Dimeblade Tribute Electric Guitar
Schecter Hellraiser C-1 question
Yes, you can install a Floyd Rose later, but it will cost you more to buy one later and install than if you were to purchase the Schecter with it already installed. A Floyd Rose bridge with trem can cost between $40.00 for a used one, to $80.00, or even higher, depending on the features you want. If you need it installed for you, you are looking at another $50.00 to $100.00 potentially.
If you are unable to purchase the one without the Floyd Rose bridge because the cost is a bit out of your reach, don't worry. Schecter C-1 guitars are well made and sound very nice, and you would still have a really nice guitar. I have owned two Schecters , and still kick myself for having sold them to "upgrade" to a Gibson Les Paul Standard. Just because it reads Gibson on the headstock, doesn't necessarily mean it's a better guitar. To prove that, check out reviews on Harmony Central sometime (www.harmony-central.com) and see how many people are displeased with their Gibsons, and how many are pleased with their Schecters.
But you don't have to worry about installation of a FL bridge later, as they fit exactly where the standard bridge and stop tailpiece are fitted.
I hope this helps.
Jul 16, 2009 | Schecter C 1 Hellraiser Electric Guitar
Acoustic Guitar - Poor Sound Quality/Tone
might just be the pickups and their age. or a faulty cable
Apr 02, 2009 | Washburn Music
Problem with volume dials in an electric guitar.
If you can't clean the pots or if you just want to try replacing them, try using
500k pots again, in case one or both of the pots is worn or dirty or
defective. If that doesn't work, and cleaning or replacing the
switches doesn't work, then the problem is probably elsewhere.
You could put a 500k resistor (with a sufficiently-high power rating of at least half the power rating (Watts) of the pot) in parallel with the pot, or, to cover all bases, put a 500k resistor from each of the two outer lugs of the pot to the middle lug. That should change it into the equivalent of a 250k pot. You could even just temporarily clip the resistors on, with alligator-clip leads, if you're very careful, just to test it.
Good luck,
The dude.
Aug 07, 2008 | Dean Dimeblade Tribute Electric Guitar
Guitar Repair - Small damage near the bridge.
I've had 50-50 luck with steaming dings using a thin cloth folded over a couple times and an iron. Sometimes it works magically, other times it doesn't do much.
Good luck.
The dude
Dean Dimeblade Tribute Electric Guitar Logo
52 people viewed this question
Top Dean Music Experts
Michial Gueffroy
Tom Rood
Level 1 Expert
rhodesworks
Are you a Dean Music Expert? Answer questions, earn points and help others
