Question about Westinghouse SK-32H240S Television
I AM SUPPOSE TO PLACE THE TV ON CHANNEL THREE TO PICKUP SATALITE FEED. SINCE THERE IS NO CHANNEL 3 IN AREA IT WONT SWAP FROM ARIAL TO SAT RECIEVER
    Problem Solver:
  • 8 Answers
You use channel 3 if you are going to use coax cable to feed your TV from the sat receiver.. Some sats will use Channel 60 or something in that range. You should use Audio/video cables for you Sat feed.
Posted on Apr 30, 2010
How do I hook up a HDTV to an old satalite reciever ?
Composite to HDMI converter/upscaler
https://www.youtube.com/watch?v=Qre-GJ8oYAc
Aug 15, 2014 | Audio Players & Recorders
I just want to hook up my JVC receiver to my Samsung to Tv so I can play the tv through the receiver and take advantage of my speaker system I have HDMI in both
Your Samsung TV does not have an HDMI out put. So unless you have a cable box or satalite box you will not be able to run the sound through your receiver via HDMI. If you do have a box, then run the HDMI cable from the Box to the Reciver input. And a cable from the reciever output to the TV input. This will feed the sound through the reciever and the picture will pass through to your TV. Hope this helps.
Apr 10, 2012 | Audio Players & Recorders
Picture wont come on
hi. if any of the little copper bits are tutching the fat bit of copper in the middle of the arial that go into the back of the tv you wont get a picture and you might not have the right conecting bit from the arial to the tv as you get male and female ones. or you mite need to retune your t.v as evrything has gone digital and if something has interupted it. it will need retuneing and will need a satalite or a channel 5 arial. hope it helps thanks sean
Nov 30, 2011 | Sony KV-9PT50 Television
The dish cut out today. the satalite took hours to reset now it is on a dish infomerciall channel and our remote is not able to turn channes but still functions with the tv. we have an old box style...
Hey Ryno4606,
It is possible, while rare, for a remote to no longer be programmed to the receiver after a reset. To fix that a simple readdress should fix the problem. I have provided the steps below to assist you with that!
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test remote and see if works.
Let me know if you have any other questions!
Tommy Faust
DISH Network
Sep 14, 2011 | DISH Network 322 DTV Receiver
We lost local tv from Dish on one of the local channels. We want to use the TV (model LC-46D85U) to view the local channel. How do we get the TV to view in local over the air instead of the satellite. ...
Connect air antenna to RF(coax) input of tv. Go to the menu and look for channel setup.Select antenna and auto scan. When done scanning you should have whatever stations you are able to pickup. Connect Sat reciever to one of the other input on the tv. Then go to INPUT or SOURCE on remote and select tv for local and what ever input you sat box is connected to for dish.
Mar 07, 2011 | Sharp Televison & Video
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
Used receiver at different location for 3 months.
Had repair man come. The coax connection going to TV from receiver had went bad in the receiver. The other connectors in box worked but not the coax anymore that is why the box worked on other TV since using video and sound cables. Got new box for signing up for another 18 months with Direct TV. Didn't have to have splitter to just get Satalite so that wasn't the problem at all. Any of the splitters I had would have worked.
Apr 17, 2009 | RCA R10 DIRECTV
Can't get satallite channels
If you are on Satellite then it only works off of channel 3 and you will not get any other channel on the tv set. But you will need to turn your sat box remote to change channels.
Feb 27, 2009 | Televison & Video
Hitachi 27
If the sat feed is on channel 3, and the TV is tuned in and still does not get the feed, check the feed wire to be okay. If all is okay, there is a possiblity that the tuner module in the set has failed.
Jerry G.
Apr 29, 2008 | Hitachi 27CX01B 27" TV
Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Sep 03, 2007 | Onkyo TX-SR604 Receiver
Televison & Video Logo
286 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
