Question about LG Flatron L1810B 18.1" LCD Monitor
The monitor stand by light lights up but nothing else happens! could it be a power supply problem or a fuse? thanks
  • 11,361 Answers
Try it on another PC first, we need to narrow down if it is the PC or the monitor.
If it still does not work with other PC and you want to DIY repair, then please read below and look at my albums so you will know what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Apr 30, 2010
    Master:
    Sergeant:
  • 401 Answers
CPU PROBLEM
Power up, power on light illuminates, drive light illuminates (yellow light), nothing to monitor, monitor remains black. Power supply gone or is their a reset or internal fuse for computer. Thyanks
Usually, this is a problem with the power supply. Try changing the current power supply with a new or working one. Also, check if all the cables are properly inserted. If the problem persists, you may have a defective motherboard.
Apr 06, 2011 | Computers & Internet
Yes i am tyler thank you trutech plv16320vm tv/monitor, will not come on,when you plug it in you get a red stand by light ,when you press the power on button. it goes off and nothing happens. or after u...
I would have to say that you have bad capacitors in the power supply.Open the back of the TV,and look at the can shaped items called capacitors on the board with the power cord.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Mar 08, 2011 | TruTech PLV16320 Television
No power with 700P LCD monitor, No green light, nothing. replaced 2 popped 470 25C caps. Nothing else looks bad. Board 860-ALZ-M713-F
You will need to check for any pico fuses that run along those capacitor lines they may be marked as pf or nf on the pcb
Jan 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
I have had the Hyvision MV220 monitor for 2 years now. I powered it off last night and it will not power back on this morning. There's a clear dot on the power supply and I'm not sure if it should be lit...
The light should be lit on the power supply when its plugged into the wall. Sounds to me like the power supply might be bad. Plug it into another working outlet and if it still doesn't light up then the power supply is bad.
If it lights up then you know the outlet is bad.
Dec 10, 2009 | MegaVision MV220 Monitor
Scott lct32sha No red stand by light Wont power on anymore
If the power supply is repaired, you can install it yourself and save a few $$$$ on the labor.
I repair these power supplies as well. If you need more info write to jah2mil@hotmail.com
Feb 12, 2009 | Akai LCT3201AD 32 in. LCD Television
Dimension 3000 Power up problems
Sounds like you have a bad power supply. If your computer is plugged in and you turn it on and nothing happens then replace your power supply and all will be well. And yes the monitor needs to be plugged into a outlet and also the back of the computer to work.
IF this has helped please rate
Feb 12, 2009 | Dell Dimension 3000 PC Desktop
Dead monitor dell e173fp lcd monitor
This could be either down to an internal fuse blown or the main board or the capacitor on the power supply could be faulty.
jonno
Sep 04, 2008 | Dell E173FP 17" LCD Monitor
Dell E197FP LCD Monitor won't turn on completely dead
could be dead, but check to ensure that you are using the monitor ONLY, not TV tuner device. as a standalone, not hooked to cpu if there is no power light when plugged in assume your buying a new monitor.
Jun 21, 2008 | Dell E197FP LCD Monitor
LG Flatron L1810B 18.1" LCD Monitor Logo
70 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
