Question about Frigidaire Refrigerators
Replace broked water actuator - Frigidaire Refrigerators
You will need the new actuator, regular Phillips head screwdriver, putty knife, and jeweler's screwdrivers.
1. Go to this link to view the parts diagram.
2. Carefully peel part #14 using putty knife.
3. Remove 3 screws part #43
4. Carefully remove part # 4. Note, there are fragile plastic arms that snap into place to hold the top of part #4 in place. I used a flat jeweler's screwdriver to apply pressure to the arms so they did not snap off.
5. Once you have removed #4, you will be able to see the top side of the actuator. There are three Phillips head screws which hold it in place. Just remove those screws, install the new actuator, and replace the screws. Note you may need to remove three Phillips head screws holding #8 in place to get to the screws holding top of actuator. Do this carefully or the wiring harness which attached #8 to #38c will pull out which adds extra steps (If this happens, see below).
6. Replace all parts following the above steps in reverse.
7. I used a small amount of contact cement to restick #14 but it was probably not necessary.
If you accidentally pull the wiring harness from step #5 above out, you will need to remove the circuit board cover to replug it. There are 4 tiny Phillips head screws which hold the cover in place. Remove them using a jeweler's screwdriver, replug the harness, and carefully replace the cover.
Posted on Oct 16, 2010
  • edelmont Feb 02, 2011
    It is amazing how difficult it is to connect the water tube again to the main piece. I was almost given up, but we discovered a hole on the right side that we assumed is to insert your fingers and guide the tube to its place. Voila! It worked.
1999 ford expedition actuator was re placed now my car over heated causing the water to poor out from under the car the cooland and heater hose broke what to do
If you are familiar with DIY repairs, start with replacing the hoses, and refilling coolant.
If you are not a DIY person -- find a friend who is, lacking that -- to the repair shop.
Jan 29, 2015 | Ford Cars & Trucks
1984 ford f-150. when turning the key to start it does not spring back to the run position. i've replaced the ignition switch located on top of the lower end of the column. when turning the key you can...
The actuator rod has a spring and block the returns the actuator to its normal position. Sounds like one of the three parts are broke. If this is a tilt steering column there is a two piece actuator rod. I am in the process of replacing the upper actuator rod, the pin that connects it to the lower actuator broke off. Never had any ignition problems, one day it just won't turn off due to broken actuator rod. Hope this helps you.
Jan 01, 2011 | Ford F-150 Cars & Trucks
Actuator malfunction air conditioning won't blow into car
the actuator opens the indash vents for the ac to blow into your car yours sound like they are broke and need replaced check your ac fuse see if it is blown if not then have to replace the actuator you should be able to get to it from under the passenger floor dash plastic it is by the motor if i remember correctly
Sep 24, 2010 | 2000 Cadillac DeVille
Actuator broke? how to get rear door open 1996 suburban
You will need to take the panel off from inside the door to get at the mechanism for the latch and lock.
Jul 05, 2010 | 1996 GMC Suburban
My car locks work on 3 doors, but one of the locks have to be locked manullay
which ever door it is need to remove the door panel to check linkage connection[clip may have popped off or broke ] or the lock actuator may need repair or replacement[test connection to lock actuator for power if no power test wiring if power actuator may need replacement]but most likely its the $2 clip which most auto stores carry
Jun 22, 2010 | 2002 Mini Cooper
I have a stainless steel Frigidaire side-by-side refrigerator with an ice/water dispenser in the door. The paddle on the water dispenser broke, and I need advise on how to disassemble the dispenser in...
the front cover will come off. if you dont see any screws then it WILL unsnap. look for a slot on the top or bottom of the cover. good luck some of them can be nasty
Oct 28, 2009 | Refrigerators
My rear door won't unlock when I use the remote or when I push the unlock buttong from the inside
if u hear actuator moving likely clip popped or broke off actuator rod if no sound check fuses and wiring if good will have to remove door panel to repair or replace lock
Oct 23, 2009 | 2004 Chevrolet TrailBlazer
Cleaning solution tank dumping
in some cases the reservoir that the tank sits on would have to be replaced. best way to tell is, if you take the tank off and pour a little water in the valve where the rubber gramet is. if it holds the water its good, but if it goes down without you pressing the trigger then it will be the reservoir.
Jul 27, 2009 | Hoover F5906-900 Upright Steam Vacuum
I have a 2000 ford windstar no heat still
My 99 windstar did this too. It was the blend door that the actuator motor goes into was broke. When you pull the actuator out look into the hole and see if you see a d shape piece coming out of the box if it is not d shape it is broke check out this site great photos
Feb 27, 2009 | 2000 Ford Windstar
Refrigerators Logo
388 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
