Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Not getting gas to carberator
Pour gas in carb its run
wadembly
  • 489 Answers
SOURCE: the mower will not start unless you pour a little
it could be that the floatin carb is stuck & not filling up the fuel bowl check that & see if i can further help e-mail me wade at wadembly@aol.com
Posted on Jun 28, 2009
  • 3 Answers
SOURCE: No Gas
I had the same problem on mine as well...it was the fuel line itself...it was deteriating from the inside and small pieces of rubber was blocking/clogging the line. Replaced the fuel line and works great now. May not be your problem, howevr lots of people forget about the fuel line going bad....
Posted on Jul 16, 2009
  • 110 Answers
SOURCE: wont start
You don't say what engine type, but there are a couple of possibilities.
1) Is there an electrical connection to the carb float bowl? If so, this is a shut-off solenoid, and will need 12V applied for engine to run. If this checks out, unscrew it and check it moves when voltage applied. If this checkc out, continue ....
2) If there is no connection, or there is and it's functional, check for a stuck float. If gas comes out when you unscrew the bowl nut, it's not stuck! If this checks out .....
3) Remove the carburettor and thoughely clean it. The main jet will be blocked.
Posted on Mar 10, 2010
wadembly
  • 489 Answers
SOURCE: My lt1000 mower will run if you pour gas in it it
it sounds like the float in carb is stuck or fuel pump is bad
Posted on Jun 28, 2010
vincob
  • 718 Answers
SOURCE: I have a dlt 3000 18.5 hp thats been sitting for
You didn't clean the carb good enough try again. You missed some small orifice somewhere. Good Luck!
Posted on Aug 14, 2010
Why is Car orator is pouring gas out and is not running ?
I assume you found the contaminates collected in the bottom of the bell housing.
remove the housing again and make sure the float switch is seated properly. If it has stuck in the low position gas will continue to feed and overflow the carb.
Jul 25, 2014 | 1999 kawasaki VN 800 Vulcan Classic
Gasoline pouring out od carberator,what is cauing this ? help
You said you replaced the needle, but did you replace the seat that the needle moves in to? If the seat is bad, it may not be sealing well even when the carb is full of gas and the float is pushing the needle in to the closed position. If it is a tecumseh carb, you can buy a kit that comes with a new needle, new seat, new bowl gasket and new bowl nut gasket. The kit is about 3 dollars and should fix you up. The kit i am referring to is part #1606506, but you may want to check and make sure that will work for your model. Regardless, the same pieces that fit your carb should do the trick.
Dec 27, 2013 | Garden
My carb on my toy 86 pickup is not getting gas when I press on the pedal. the acceleartion pump seems to be pumping OK, but no gas is coming thru the line that squirts into the carberator chamber. I can...
something is clogged. Recommend rebuilding the carb. The rebuild kits usually come with instructions--enough to get you thru if you are handy. Or, you could just take the cover off the float bowl right there on the engine and see if you can find the clog. Especially check the jet(s) in the bottom of the bowl. Any more questions--let us know.
Oct 04, 2010 | 1986 Toyota Pickup 4WD
I have a 2004 fxd i have gas pouring out of
its a carberator fault the float valve is stuck down and its flooding the carb,,strip the carb and free off the float valve it may need a new one fitted!!!
Jan 23, 2010 | 2004 Harley Davidson FXD - FXDI Dyna Super...
2000 cavalier ran out of gas now it wont work
Remove the coveer to the carberator. Pour some gas into the carberator. If it runs you are not getting any gas to the carberator. It may be the fuel pump.
Aug 20, 2009 | 2002 Chevrolet Cavalier Coupe
Won't continue running
This unit has a fuel solenoid on the carberator, which opens to allow fuel to the carberator. Check to see if this solenoid opens while cranking.
May 07, 2009 | Electrical Supplies
Fuel problem?
there is a fuel metering system inside carburetor that does this when it fails ..go to reputable carb shop for test and replacement
Nov 10, 2008 | 1987 Nissan Sentra Wagon
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
134 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
