Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
Makes noise vibrates when fan is running - GE Adora (DSF25KGTBG) Side by Side Refrigerator
  • GE Master
  • 43,501 Answers
The fans for those often bend or get out of balance...the best thing to do is to just replace the fan..have tried fixing them and the fix is only temporary once you start having problems...
heatman101
Posted on Apr 30, 2010
Maytag over range rattling and vibrating noise
Make sure you tighten all the attachment screws that may have loosened during long term usage. Make sure the fan is running properly and not causing undue vibrations. Use WD 40 on the fan.
Mar 15, 2014 | Maytag Appliances Over-the-Range Microwave...
My Candy TC21 oven makes a vibrating noise when on, why is that?
There are only 2 moving parts in your oven when it is running - the fan and the fan motor. If a bearing is worn or the fan blade is damaged, this can cause vibration. However, the actual noise could be could be coming from some other part of the oven which is insecurely fixed, e.g a panel, internal shelf, the oven/grill element - pretty much anything!
Basically, the fan/motor causes the vibration and a loose part causes the noise.
Hope this helps.
Regards,
BElectric
Nov 14, 2010 | Ovens
Loud humming noise (vibration) from freezer section when running. Amana refrigerator (freezer on bottom) model BC21VW
Remove the back panel and see if the fan is turning. You will need it in the running cycle with the door switch closed. The noise your hearing is probally the fan assembly AP4008960. Make sure it is mounted tight and the back panel is not rubbing or loose. If the fan is making noise with the panel removed replace.
Mar 24, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
GE top freezer refrigerator: motor has become very loud and refrigerator vibrates. However, when I move the cold control to a lower number, it gets slightly quieter and vibrates slightly less.
Please make sure it is level, the compressor is designed to run on level ground. Also check the fans. if the fan is bad or the bearings are shot, it'll vibrate and make a loud humming noise.
Find out where the noise is loudest. if it's under the fridge, it's the compressor.You have to check the coil for the compressor and if it's inside the freezer, it's the fan bearing.
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 20, 2009 | Refrigerators
Blower fan in the freezer is making a vibrating
only if the fan noise is driving you crazy. the noise is probaly the motor starting to go out. you can replace it. it might save you money in the long run to replace it, if it goes out you could run into bad food in your fridge.
Jun 26, 2009 | GE GSS20IEM Side by Side Refrigerator
Motor noise coming from hp designjet 120 nr
The fan is probably filled with dust. This can throw the balance off and make vibrations or cause resistance which can make a humm, not necessarily a bearing, not sure if the fan even has bearings. Anyway, the intermittent noise can be that the fans only run when the printer is hot. Find where the noise is coming from clean off the blades and components with a damp rag, blow around or lubricate the center of the fan, and replace it in the printer. Should fix it.
Dec 10, 2008 | HP DesignJet 120nr InkJet Printer
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
108 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
