Mitsubishi VS6004R Big screen-help to bypass the pip.
I am having trouble with my pip and woud like to bypass the pip in this unit. Does anyone have the schematics or could tell me where the pip module is?
  • 53 Answers
Well if you are electrically inclined, the service manual for your tv ought to have more info on that. servicemanual.net I think. You have to pay, of course, but you can get a PDF.
Posted on Mar 25, 2008
SOURCE:
Mitsubishi CS-35301 has a rolling screen. Need to access service menu.
you need replace capacitors in vert.output circ. Not a service menu.
Jan 28, 2010 | Televison & Video
I have a Mitsubishi Big Screen TV that is about 20 years old. There seems to be a problem with the PIP. The entire middle of the TV screen goes black, you can see the outside edge of the program in the...
i have the solution. common problem. it has a pip module with defective (leaky) capacitors. they are surface mount capcitors. mcm has a mitsubishi pip module repair kit order number 32-11755 $14.95. 1800 543-4330 customer service 1877626-3532. www. mcminone.com
Nov 15, 2009 | Televison & Video
When i turn my mitsubishi tv on the picture jumps it a 1993 big screen.
it needs either the pip module bypassed because the pip board is no longer available, or vertical capacitors or connections, very common complaints.
Aug 31, 2009 | Mitsubishi WS-55511 55" Rear Projection...
4 Scrolling black boxes with the picture showing in the background
PIP DISPLAYED IN ALL FOUR CORNERS OF PIX. UNPLUG UNIT MOMENTARILY TO RESET. or the pip modual has failed.
Mar 16, 2008 | Televison & Video
Scrolling picture on an old big screen
These models have been known to have faulty capacitors on the PIP module as a result thy loose vertical synvh and the picure will roll. The PIP module is no longer available. But if you would like I can post a way for you to bypass the module and if the modle is at fault your tv will work fine, but you wont have PIP anylonger
Feb 23, 2008 | Mitsubishi VS-60719 60" Rear Projection...
Mitsubishi VS-50VA1 schematics or resistor ID
Perform PIP bypass (must give up PIP function) 1)remove PIP module,leave out. 2)Install 22mf/50v NP caps on bottom of PCB. Mount cap to VP pins 5 to 11. " " " " " 7 to 9. Re-check video=should be clean.
Aug 22, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Blue screen
check the agc circuit it is becomming defected.good luck.
May 16, 2007 | Mitsubishi VS-60703 60" Rear Projection...
Sound no picture
You can buy a PIP circuit card on the internet(about $15.00) that can replace your current PIP card. It will bypass the PIP function which is most likely the problem. Instructions for instal come with new card. It's a relatvely easy task if you are in anyway technically capable. Worth the try. Rexman
Apr 05, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
Ekse
