Question about Nokia 5140 Cellular Phone
Nokia 5140 Hi I need a new charging/headset socket assembly for a Nokia 5140, where can i get one from. The charger is fine and the battery is fine, but when i attach the charger nothing happens.
  • 1,665 Answers
My Nokia BH-503 Suddenly Change in to ISSC-SHS and not charging
How long have you had this item? It could be the lithium battery in phone? I would encourage you to take the set up to Batteries etc: and let them check battery. Please leave me some feedback
Jul 08, 2016 | Nokia BH-503 Bluetooth Headset
My blueparrott not taking a charge can any one help me
It is actually very easy to remove the battery on the BlueParrott B250-XT. To remove the earpiece, just pull it out of the socket but be careful not to pull the wire attached to it when you separate it from the body. Next, remove the five screws to access the battery compartment. Disconnect the battery from the board and leave it disconnected for 10 minutes or so. Re-connect the battery and re-assemble. Connect the headset to your charger and after a couple of minutes, it should start charging showing red until fully charged. If it still won't charge, you may have to order a new battery. You can find a replacement battery on EBAY for around 10 dollars. Repeat the battery replacement and check to see if it starts to charge. If it works, you are good to go. If it does no work, you may have to send it to the manufacturer for repair. Good Luck!
Nov 11, 2014 | VXI Corporation Blueparrott B250-XT...
My nokia e63 does not charge. I buy new battery but same problem were encountered. What will I do? tnx n good day.
Does work all ok and dont charge? Maybe its broken dc jack connector, or the charger or a fuse inside. Try with usb on pc some nokia can charge from pc.
Jun 30, 2011 | Nokia E63 Cell Phone
I m not able to connect my BH 208 headset to nokia E71 set
Make sure that the headset is properly charged before following the instructions below.Please follow the detailed instructions in the correct manner to successfully pair your Nokia E71 with the BH-208 Headset.
Charge the battery
The headset has an internal, non removable, rechargeable battery.Do not attempt to remove the battery from the device, as you may damage the device.
1. Connect the charger to a wall outlet.
2. Connect the charger cable to the charger connector. The red indicator light is on while charging.
It may take a while before charging
Switch the headset on or off
To switch on, press and hold the power key until the headset beeps and the green indicator light is displayed. To switch off, press and hold the power key until the headset beeps and the red indicator light is displayed briefly.
Pairing the headset
1. Ensure that your phone is switched on and the headset is switched off.
2. Press and hold the power key until the green indicator light starts to flash quickly.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the phone menu where you can view the currently paired Bluetooth devices.The headset is now ready for use.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
Jun 14, 2011 | Nokia BH-208 Wireless Headset
It did not charge
The you have either not inserted the charging plug fully, the charging socket is faulty, the charger is not working, or the battery has failed.
I'll assume that you're familiar enough with your headset not to have done the first option. The charging socket is probably ok if there's no obvious visible damage and it's likely that the charger is working too as they're so reliable, but you can always eliminate it as a possibility by borrowing another charger or testing the socket output against the figures printed on the charger.
But by far the most likely culprit is the built-in rechargeable battery. It's not designed to be replaceable as the complete headset is only expected to last two years, but Jabra do have a one year warranty on it: if it fails they just exchange the complete headset for a new one (or the charger if that proves faulty). Your unit can't be very old as the model is a fairly recent one, so you should first try for a repair, refund or replacement (your choice) from the retailer (a legal right under the Sale of Goods Act if you're in the UK) and then contact Jabra directly if either the retailer won't help or if Jabra has told them to refer all repair claims to them.
You'll find a link to the warranty terms here.
May 07, 2010 | Jabra BT800 Consumer Headset
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
Dec 11, 2009 | Nokia N95 Cellular Phone
Charging problem nokia 1110
If the phone is not charging or charging is irregular, then problem is either battery , charger socket on phone, or charger itself.
If it does not charge at all, then it is either the battery or the charger.
If it does not hold charge then it is the battery.
If charging is erratical then it is either the charger connector/socket, or the ac charger.
The best thing to do is going to a phone shop, having the charger and the battery checked by the guys at the shop and replacing either the battery or the phone charger.
Mar 04, 2009 | Nokia 1600 Cellular Phone
Unlock code for nokia 5140
You won,t be able to unlock this Phone. On This site.
IMEI Is a security encoded Phone, that allows only the authorized user. to change or unlock it from it,s network service provider.
assuming that you are the legal owner of the phone, you can take it to your local mobile phone shop, they will run a computer program on it. which will then authenticate the phone. whether it,s been reported stolen-lost or missing. and if it,s on a contract agreement with the 3 network.
If the phone is completely legitimate, and is not locked on a contract plan with 3.
your mobile phone shop will charge you approximately. £20-£35 or $50+ to unlock the phone, to enable a new sim-card to be inserted.
Mike @ Compurepair.
Jun 13, 2008 | Nokia 5100/6100/6300/7100 Series Black...
Nokia 5140 Cellular Phone Logo
229 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
