Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Pt61lcx65 ty-la1000 bulb needed with plug in socket. (only see for other models) The housing is fine, the bulb is shattered inside. Referral for replacement bulb please? I'm getting dizzy trying to find the 'solderless' bulb with the plugs. Any help is welcomed.
How do u reset when the error message appears on my pansonic tv using a TY-LA-1000 bulb?
Posted on May 03, 2010
  • 2,336 Answers
You can find the lamp for your DLP on this link.
Let me know if you require further assistance.
Posted on Apr 30, 2010
TV won't power on
Sounds like the bulb is not firing. I have the 44 inch model. Like it too. It is normal for the power indicator to blink for a minute or two AFTER the set has been turned off from running. get a phillips or panasonic TY-LA1000 bulb or a P22H 120 watt one if you can remove the old one from the housing (not very hard to do).
Mar 31, 2014 | Panasonic PT-52LCX65 44" HDTV
TY-LA 1000 loose wire
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 21, 2014 | Panasonic TY-LA1000 Projector Lamp for...
I need the female connector that plugs into the ty-la1000 lamp unit. What is that connector called or where can I find one?
If you mean the socket where the lamp plugs in it is a part of the Ballast which powers the lamp--I doubt it is sold by itself. You likely would have to buy another ballast--how is it damaged?
Dec 17, 2012 | Televison & Video
After just recently replacing the bulb I am
Here is proceudre to reset lamp timer in your TV..
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
Hope this info will help you.
Thanks.
Nov 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
I need the instructions to install the bulb only for my Panasonic PT-52lcx35. I have the replacement bulb already and want to install it into the original housing.
Hello! Here you go. click on the link or copy it http://guides.fixyourdlp.com/panasonic/TY-LA1000.php/?Click=48427 it's a picture guide and also a video of how to replace the lamp. It's really easy, good luck!
Nov 05, 2009 | Panasonic Televison & Video
I need to replace the lamp...how do i get it out?
Hi, well your TV uses the lamp enclosure TY-LA1000, here is a link where you can find the manual of how to get to the enclosure http://www.fixyourdlp.com/blog/2007/09/17/panasonic-ty-la1000-enclosure-replacement-instructions-guide/ and here is another one to replace the lamp on the enclosure http://guides.fixyourdlp.com/panasonic/TY-LA1000.php
Jun 27, 2009 | Panasonic PT-52LCX65 44" HDTV
Made a pop sound then screen went black- won't power back on
I'm sure you've resolved this by now, but I am brand new to this site and have the same TV, and have had the same issue. Sorry it's a bit late.
The pop was definitely the bulb bursting. You can pretty easily do this bulb replacement yourself as Panasonic has provided a nice little pull out module that can be removed by popping the front plate off (which requires no tools at all) and then opening the hatch where the bulb assembly is and loosening just one screw. Once that is done you will be able to slide the entire bulb assembly out of the TV. Though they don't always shatter, I suspect that since you heard it "pop", you will find this assembly full of broken glass.
You can either buy an entire new assembly such as this one...
http://www.alltvlamps.com/product_p/ty-la1000.htm
and just slide the new one in,
or if you're comfortable with it, you can open this lamp assembly up by removing just a few more screws (about 4) and just replacing the bulb. I did need to buy a very long #2 Phillips head screw driver to reach one of the screws.
If you search Google for TY-LA1000 you will find both the lamp kit and just the bulb. Be careful though for the really cheap bulbs, it does make a difference, so if it seems drastically cheaper than all the others, there is likely a reason.
Hope this helps you and sorry for the slow response.
-R
Nov 23, 2008 | Panasonic PT-44LCX65 Television
Panasonic lamp
Brian, I just helped my buddy replace his Panasonic ty-la 1000 bulb this weekend. I have to tell you that I have a complete illiteracy when it comes to electronics but we got it done in about twenty minutes and were watching it again. Looks great. We ordered the bulb from dlp lamps.com and had it in about two days. They also had super easy instructions to follow. Try it before you replace the entire TV.
Sep 07, 2008 | Panasonic TY-LA1000 Projector Lamp for...
Removal of projector bulb housing
Here is a better site for instructions. It has a .pdf file.
http://www.911phone.net/Panasonic_TY-LA1000_Instruction_Manual%5B2%5D.pdf
Feb 21, 2008 | Panasonic PT-50LC13 50" Rear Projection...
HBE  1-800-848-6888 TY-LA-1000 ==PTL-010 complete housing
239.00, lamp only==229.00.
I never replace lamp only-------T.
Oct 23, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
118 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
