Question about Splendide Washing Machines
I have a Splendide electric dryer model AS66VX stackable unit in my RV and the drive belt failed. How do I remove and replace the belt. Does the front come off to give access to belt removal and replacement? Thanks for the help. twojunkers@frontier.com
  • 273 Answers
The belt appears to be behind the drum, not around the center of the drum as is the case with most domestic units.
See the parts diagram with exploded view here:
www.splendide.com/service/AS66VX_Parts.pdf
Posted on Apr 30, 2010
Plugged into bad electric, Washer/dryer combo does not power on now
if your appliances all blew they may have been fuse protected, such as tv's and microwave have inside them. Power converter should be fuse protected as well. If the plug was wired incorrectly was it a fifty amp service or thirty? Does your power run threw a transfer switch? look there as well. typically voltage spikes threw ground circuits take out your electronics. Using ground fault interruption circuits and voltage protectors in between your plug and power supply will prevent most/some damage. many variables to pinpoint without input.
Nov 11, 2012 | Splendide 2100 Front Load Washer / Dryer
Splendide 2000 Model Help Needed
I have the same problem with my WD802 "pre M". I have found this forum and it as helped me some. Here is one forum that might help you - http://applianceguru.com/forum2/17215.html - I think it's my control module, but I cannot find a test guide for my "pre M" WD802 module. I am Calling Splendide first thing tuesday to see if they have a tech manual for the "Pre M" models. Good luck with your WD802.
Jun 29, 2010 | Splendide 2000S Front Load Washer / Dryer
Wet clothes in splendide 2000 S door won't open
drive motor or belt came off or broke take off top
Mar 23, 2009 | Splendide 2000S Vented Washer/Dryer
Need to replace dryer belt.
screw on bracket of motor for tentsion release
Jan 24, 2009 | Whirlpool LEW0050P Electric Dryer
Splendide Comb-o-matic 2000 how do you vent it to the outside
Use 2.5" plastic pipe & elbow to replace aluminum elbow & hose with spring inside. Air velocity is higher, lint blows out without collecting.
I used wood router to remove part of exhaust connector on rear of dryer to better fit elbow. Elbow interior was smoothed to prevent lint sticking. Elbow was mounted with silicone sealant and 2 screws. Pipe was glued to elbow as normal glued pipe connection. Pipe end was cut even with side of dryer.
After Spendide was installed in RV, a union was stuck in from outside RV. Union slides on to pipe without sealant so Splendide can be removed from RV. Union better fills outside vent fitting than bare 2.5" plastic pipe. Temporary seal aroung union was made of urethane foam scraps, common shipping stuff from a computer monitor box. After 2 years of temporary, the foam is now considered permanent.
Original problem was constant lint problems in hose and slow drying. With pipe, not hose, lint is rarely cleaned and drying is much faster.
Dec 26, 2008 | Splendide 2100 Vented Washer-Dryer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Splendide 2000S
www.splendide.com
1-800-356-0766 #5 (503-656-2280)
503-722-9202
service@westlandsales.com
Monday-Friday, 7:00am - 4:30pm (PST)
You may also want to try a RV retailer in your area, they may direct you to a used part.
Jun 10, 2008 | Splendide 2000S Vented Washer/Dryer
Washing Machines Logo
364 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
