Question about Maytag Neptune MAH5500B Front Load Washer
WASHER NOT DRAINING on the time indicator the letters nd are displayed and the washer is not completing the wash. water is still in machine
  • 26 Answers
I suspect that something is stuck in the pump. The code is telling you what you already know - there is a drain problem :) I have found many a bobby pin or underwire in there! Best way to drain the machine, in my experience, is to use a shop vac and **** through the drain hose. Good luck!
Posted on Apr 30, 2010
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Amana front load washer
nd--Washer is not draining/Washer senses a brief restriction while draining
Nov 17, 2013 | Washing Machines
My washing machine is displaying the letters "nd",
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
Feb 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Stopped with a load and water displayed a code of nd
When error code "nd " flashes remove water pump, check for thongs, baby socks and sometimes hair pins or even screws can obstruct the water pump.
Simply remove the pump and remove the obstruction that is keeping it from draining. This will fix your problem.
Thank you !!
Jul 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
Code nd...Washer will not drain.
Check the following to address the no draining issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 02, 2009 | Maytag Washing Machines
Code nd FAV6800AWW, Serial number 10
Hello HopelessR,
Don’t buy a clutch I don’t feel it’s a clutch issue at this point. I hope you can hang in there for some basic troubleshooting. I’m an owner like you not a repair person but I have worked some issues. I feel with the info supplied that you have a true “nd” alarm. The “nd” alarm is triggered when the washer fails to drain completely as monitored by the pressure switch input to the control board and the factory program time limit required for draining the washer. I have never experienced an “nd” alarm until this evening. This was a user induced “nd” failure by pumping wash water back into the tub during the drain cycle of Quick Wash cycle. I started a Quick Wash cycle with no clothes in the washer and with the remaining three settings set to min settings. At the 22 min mark the washer started the drain pump and began a slow spin CCW of the wash basket. It took several minutes of pumping wash water back into the wash tub to trigger “nd” alarm. The washer indicated time stayed at the 21 min mark until the “nd” alarm triggered. 1st test; could you start a Quick Wash cycle with what you would consider a full wash load with the settings I mentioned and let’s see what the results are. I don’t feel you have a clutch issue with no dc/UC error codes to the console. I believe at this point that you have a drain restriction problem. I can’t explain why the washer completes the cycle with the wash basket empty at this point. The 2nd test, do you have a deep sink you can pump the wash water into and observe the stream output? The stream my FAV6800AWW will produce is about a 3” vertical column of water out of the drain pipe held over the deep sink with the drain pump running and no clothes in the wash basket. If you have a deep sink and a helper that can turn on the drain pump in service mode as outlined below we can compare your drain pump output to mine.
You can turn on the drain pump in Service Mode with the process below.
1. Enter Service Mode by pressing both the Enviro Plus and Spin Only keys simultaneously until the washer beeps.
2. Next you need to go into the Board Output Test by pressing the Delicates key; your display should now read “ot”.
3. Now press the Presoak key this will start the drain pump and it should begin to empty the tub.
You can press the Off button to stop the drain pump.
If the output stream is low we can troubleshoot the restriction starting at the Sump Cap Item 9 and work back toward the drain pump.
I’ll hang in there with you if you want to continue to troubleshoot the issue. Maybe we can get some suggestions from other forum members. Rich
The Service Manual for reference. Sears Parts Direct for reference.
May 12, 2009 | Maytag Neptune FAV6800AW Top Load Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Nf pops up on the screen & the washer stops
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
May 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
377 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
