Question about Whirlpool GB9SHKXL Bottom Freezer Refrigerator
Frost accumulating in the freezer . Whirlpool Gold purchased two years ago
  • 26 Answers
Sounds like an issue with your defrost circuit. Usually the defrost terminator. It is mounted on the coil behind the panel inside the freezer. There are two wires going to it. It is the size of a quarter around and maybe an inch thick. Good luck!
Posted on Apr 30, 2010
Whirlpool Gold side by side frigerator freezer ice and water not working, inside frigerator various places freeze, on certain shelves units only 5 years old
As far as the icing up sounds like your cross over have ice. Unplug and defrost even on frost free. Should solve both problems
mike
Dec 19, 2017 | Whirlpool Refrigerators
My whirlpool gold refrig is icing on bottom of freezer. Is there any way to fix it without removing the back panel of the freezer?
You may need to manually defrost it, Even a frost free freezer can get frost. After you do that, make sure that you leave enough room for air to flow around.
Feb 11, 2015 | Whirlpool Refrigerators
Have a Whirlpool Gold fridge. Model #GB2SHDXTQ00. This week the fridge stopped working but the bottom freezer works fine. Is this just a thermostatic control issue? What part might be causing the problem? ...
Check the back wall of the freezer for frost . If there is then it is either the defrost heater, timer or thermostat. If there is no frost check to see if the fan in the freezer is running.
Oct 28, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frost accumulating on back of fridge - service light blinking
YOUR EVAPORATOR IN THE FRESH FOOD SECTION IS LEAKING FREON. THIS IS COMMON WITH EVAPORATORS IN THIS AREA. 12 PART WARRANY OR 6 YEAR FULL ON THIS. SUB ZERO HAS SUPERIOR CUSTOMEER SERVICE AND MAY COVER FULLY IF OUT OF THE 6TH YEAR. 1-800-222-7820 CALL THEM AND ASK.
Apr 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Refrigerator not cooling, only fan is running.Compressor is hot to the touch. Frost accumulating in freezer and on produce drawer temp controls
Somewhere air is getting past the door seal. The door may not be closing all the way. Frost cannot accumulate without a source of water. It comes in the air thats getting in past the seal. Check the drawers to be sure they are all the way in. Check anything that may be sticking out that may prevent the door from closing all the way. Check the door seal for damage and replace the seal if any significant damage is found. Good luck
Dec 13, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge and freezer not cold enough since we moved
remove the panel at the reaar of the freezer. you should have a full frost pattern on your evaporator (frosted not snow packed) and the fan should be running. if you do not have a full frost pattern then you have a sealed system leak. covered under the first five years of your warranty
Feb 17, 2008 | Whirlpool ED5SHAXM Side by Side...
Whirlpool GB9SHKXL Bottom Freezer Refrigerator Logo
166 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
