Question about Whirlpool Refrigerators
I bought a 9 nyr old top mount Whirlpool frig from a friend a few weeks ago. At first, it worked great, now the freezer is fine but the frig won't chill below 60 degrees. It has only one thermostat and we have triple checked to make sure all vents between freezer and frig are clear. They are both just about empty now, anyways.
  • tootiemy May 02, 2010
    Thanks Dave, we;ll try checking out the fan and get back to you. Hopefully it is the solution and it's not a costily repair.
  • 11,800 Answers
If you have tried with the frig filled and it's the same then the thermostat is faulty.  It can't be fixed, replace it.
Posted on May 02, 2010
  • 154 Answers
Theres a fan located next to the compressor replace that!!!! and your tempratures will be back to normal guaranteed
Posted on Apr 30, 2010
  • dave taylor May 02, 2010
    isyour problem solved?
  • dave taylor May 07, 2010
    did you end up checking to see if it was the fan for some reason it says someone else is helping you.....
Water is slowly dripping from the top of Frig.
The water is coming from the defrost cycle in the top of unit . It drains down at the back of the light cover into a tube at the back. Get a phillips screwdriver and take it down to be sure tube is inserted properly. Get model number and go to.appliancepartspros.com to get a diagram.
May 24, 2010 | Frigidaire FRT18B4A Top Freezer...
Frig cools works great all day then trips the gfci
Hi Sturkle;
Does this happen say- every 6-8hrs? If so you may find the defrost element has a short, or defrost timer is faulty. Defrost element is located in the freezer compartment, Time located an back of fridge.. Use a qualified person when playing with electrics...Cheers
Mar 29, 2010 | Whirlpool ET8GHMXLQ / ET8GHMXLT Top...
...The temperature in the frig is now + 40 degrees
uve probably got a freon leak check to see if compressor is running and fans inside are blowing if so then u probably have a freon leak
Feb 24, 2010 | Kenmore 63822 / 63824 Bottom Freezer...
Freezer way too cold - ice cream hard as a rock
The freezer may get as low as -18 degrees F or 0 F this is the point when life and bacteria stops growing.
Ice cream shouldn't be that cold unless it is whipped with air.
Feb 27, 2017 | Kenmore Refrigerators
Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Mar 06, 2009 | Whirlpool ET1FTTXK Top Freezer...
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 04, 2008 | Magic Chef Refrigerators
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
