Question about Electrical Supplies
CUMMINS ONAN BATTERY FLOAT CHARGER 12V 305-0812-01
2 Suggested Answers
palaboy
  • 5807 Answers
SOURCE: Can I charge the battery for the electric start
yes, and
• safer if you can disconnect the battery terminals from
being connected in the generator.
• even a terminal will do.
• These charger must have at least 6 A for charging purposes.
Higher rating means faster charging .
• Use a suitable automatic charger, if available.
One which automatically cut-off charging current when the
battery has reach fully charge state.
Posted on Jul 30, 2012
WE are having carburetor problems with our Cummins Onan RV generator RVQG5500. When we hold the choke down or spray gas into it, it will run, but as soon as we quit doing this it stops
Have you checked for a clogged fuel filter? Does the carburetor have a float? If so, maybe the float needle is getting stuck! Are you using ethanol-laced gasoline ... which can DISSOLVE viton-tipped needle valves?
May 12, 2017 | Electrical Supplies
My onan 4.0 grenerator motor will not idle and it is back fireing while trying to run is in the valves
If it is backfiring even during idle, there are a couple of possible issues. Check the obvious and least expensive first. Make sure you have correct OEM spark plugs, check ignition wires. Then check the ignition coil and trigger module, there is a procedure for doing that in the Cummins Onan manual. A manual can be obtained from http://www.advanced-power-technologies.com/ or local Onan RV dealer. This will give you the ignition coil resistance and the ignition module resistance. Also has anyone messed around with the carb, or has it sat for long periods, too lean a fuel mixture can cause backfiring. Good Luck ;)
Feb 11, 2015 | Onan CUMMINS 4.0 KYFA/6747 - Cummins...
Onao generator fuel pump loses power
Is it losing Battery power, or just not pumping? check connections, and pins on board connector. Failing that replace the board, if Battery voltage is been lost
Jul 26, 2014 | Onan CUMMINS 5.5 HGJAB-6755 - Cummins...
Onan 5.5 Hgjab Generator Manual
Gap is 0.025" plug is a NGKR BPR4EY
Cummins part # 167-1638
Jul 26, 2013 | Onan Cummins 5.5 HGJAB-901 RV QG 5500...
Onan quiet diesel 6000 won't crank clicks
Check battery voltage, starter solenoid, then starter motor
Mar 31, 2013 | Onan Cummins 12.5 HDKCB/11506 RV QD 12500...
GETTING FAULT #36 ON CUMMINS ONAN MODEL#GSBB WHAT TO DO
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Mar 19, 2013 | Onan Cummins A029J885 - Alternator Dryer...
Onan 5500 RV generator starting issue
Sound like a dead battery, or poor battery volatge getting to the unit. The clicking is fuel pump and or solenoid trying to pull in.
Sep 12, 2012 | Onan Cummins 5.5 HGJAB-901 RV QG 5500...
Can I charge the battery for the electric start from the dc 12v outlet and the cord with the plug and battery clips? I have an onan pro6000e generator.
yes, and
Jul 27, 2012 | Hammering
Electrical Supplies Logo
839 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
