Question about Philips 19PR19 19" TV
After Power outage - picture is larger than screen
After a power outage, the display on our tv is now larger than the tv screen area. Part of the show is off the screen. For example, while watching a ballgame, the score shown on the top left-hand corner is partially off the screen! We have this problem on a couple of our TV's after the outage and on one of them (also a Phillips Magnavox but a smaller set) we were able to change one of the settings from Expand 4:3 format to just 4:3 format and it improved a little but not completely. On the other TV (Phillips 19PR21 19") set I cannot find a way to change this setting.
Any ideas why this happened and how to fix it?
Thanks, Steve
Sound problem tda 9370/1783
Posted on Apr 24, 2011
  • 901 Answers
This TV also should have similar facility like 19" Tv. Try the menu, it may be in different name or classification. I do not suspect circuit fault. If you can access service menu code you can try. Better take assistance from service center. If you access service menu, do not for get to note down the values in each and every step.
Posted on Apr 30, 2010
No picture, just sound on Etec Flat Panel 40A99
Video circuit is separate from the Audio circuit. The main controller may switch to Audio, but if the unit is damaged from a power outage; part of the circuit board may not function. Needs professional servicing.
Feb 26, 2014 | Cars & Trucks
Had a power outage and now my TV is not showing any pictures except for the blue screenn
Outage may have changed the input channel on TV so make sure you're on the right one. Press and hold the Power button on cable box. Let that restart. Unplug the router for 10 seconds and let it boot up.
Feb 07, 2014 | AT&T UVerse
Sony KDL-V32XBR1 Displays only snowy picture
Here are a few more troubleshooting steps you can try when your TV picture is just snow. I see that you have already rebooted your TV, but did you turn your set-top box off and on, too?
1. Does the picture show when you play a DVD?
2. Check all of the connections between the TV, outlet and set-top box and make sure everything is secured.
3. Is your TV set to the correct channel (typically 3, but in some areas 2 or 4)?
4. Press any key on the remote to see if the correct mode lights up. (Ex: if you have cable, the cable button should light up). If it doesn't, press the correct mode's button to regain control and change channels.
5. Call your service provider and make sure it's not an overall service outage.
6. Do you have sound but no picture? If so, it could mean a backlight failure.
For more suggestions, see TV black screen or snowy screen for troubleshooting and solutions. I hope this helps!
Sep 20, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
1.My toshiba 32wlt66 has a display of thin light green colour line showing from the screen from the left end to the right end, very visible in dark pictures, 2. The TV power on by itself whenever I plug...
1. there is porblem with the lcd screen. if it is in warranty, have it replaced or repaired
2. some tvs save the last state it was in in case of power outages. taking it out of the power source will have the same effect. so turn off the tv before unplugging it.
hope the above answers your questions
thank you for visitng fixya.com
Jul 06, 2011 | Toshiba 32WLT66 32 in. LCD HDTV
VCR will not show picture or menu on TV after power outage.
Hate to say this, but when power outages occur, things like vcr's are the first thing to fry. But if you feel that the vcr is fine as far as powering up, then unplug it from the wall socket for 30 minutes or so, plug back in and see results.
Apr 13, 2010 | Televison & Video
When TV is off and there is a power outage the TV
This TV has a Power Standby feature (pg. 40 of your manual) which allows you to more quickly turn ON the TV. When power is lost and then restored, your TV will display the HP logo screen while it boots the digital circuits. After it is finished, (unless it was previously turned on) it should appear to be OFF. This is normal operation. If you like, you can change this setting to LOW POWER. At this setting, each time you turn on the TV, you will see the HP Logo screen and picture/sound will appear after 20 seconds. Again, take a look at pg. 40 of your owners manual for more information.
Mar 15, 2010 | HP PL4260N 42 in. Plasma HDTV
Picture is larger than display area
Check the aspect ratio settings you may have it set to 14:9 movie expand
Jan 30, 2010 | Samsung HL-P6163W 61" TV
My tv keeps popping up a black box about one third the size of the screen . how do I stop it
If you have dual tuner / PNP then follow Solution #1
If you just has a power outage or after a move then give the following a try.
You have to go into the TV menu setup screen.
After a power outage the memory will go back to factory default.
Don't be surprise if it's display is not in English.
The black box is field for close caption (CC).
There are many transmission methods.
Go to the Close caption (CC) page and turn it off and save the setting.
Oct 18, 2009 | Televison & Video
Mitsubishi 45" Projection TV
You may need to replace the color wheel or the power outage may have damaged the DMD board too
Jan 05, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Philips 19PR19 19" TV Logo
160 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
