Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
I cannot access my 320 GB simpledrive. It asks do you want to format drive?
    Problem Solver:
  • 19 Answers
As you are getting promt of format drive that confirms that your system is able to detect your 320 GB simpledrive.
If you are using it first time then by default you will get this promt and if you are already using it from a long time then your data which is in the drive got corrupt and that's the main reason you are getting this promt of format drive. You need to click on yes to format it.
There is no other option. You will need to format the drive and you will loose your data which you have in it.
Take Care
Posted on Apr 30, 2010
I have a Simpledrive 500 GB and I don't use it frequently. Now, my computer asks me to format it. I won't lose my information, what do I have to do?
ok somewhere there has been a fault which has rendered it unreadable in windows, but info still can be pulled off via a Linux Live disc, that is a small operating system like windows that will run off a cd or flash drive, once up and running you can access the hard drive and copy all info to another, then when back in windows you can re formatt and send all info back, I know it sounds a little hard but it is not.
Cheers
Sep 24, 2012 | SimpleTech by Hitachi SimpleDrive 500GB,...
MY PC WINDOWS XP ASKS TO FORMAT MY STOREJET 25 320 GB TRANSCEND PORTABLE HARD DRIVE
If it's asking to be formatted you need data recovery help. For remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 04, 2012 | Transcend StoreJet 25 Mobile - Hard drive...
SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue: HELP. I have simlple tech 320 external hardirve. M...
Were you using this on a PC? it may be using Fat or NTFS. If it's seeing the drive and you can't use it, it may be the filing system, I believe macs use a different one than PC's. I would copy the files "if possible" to another flash drive or computer and just re format the 320 gig drive, the mac will install the right filing system for the drive and it should be good to go.
May 16, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Black
Try to go through disk management and see if it works?
Open control panel then select administrative tools then disk management. Then in left column click disk management.
If you locate it may be it must be initialise by the system or need to create partition by formatting.
You can also check all the cables , the power cables the adapter , try to change the Usb cable also..
ok
Good luck !!
Jan 22, 2010 | SimpleTech 320GB SimpleDrive External by...
SimpleDrive 160 GB drive is recognized by XP, but cannot access. Have tried on 4 computers. Properties show 0 bytes size and 0 bytes free. Can't even Format Drive. This happened after interrupting an...
The drive was damaged during the interuption. This has happened to alot of my flash drives and there is not way to fix it. You can, however, replace the hard drive in the case. Open the case and you will see a small laptop hard drive (that's all it is), purchase a new replacement and throw it in there.
Oct 04, 2009 | SimpleTech SimpleDrive 160 GB External USB...
Simple tech drive
Using this program http://www.ridgecrop.demon.co.uk/dow...at32format.zip
Its worked perfectly on my 300GB usb drive, my PS3 can see it just fine
Oh and it works on vista as thats what i did it on..
Aug 01, 2009 | SimpleTech 320GB SimpleDrive External by...
Simpletech 320 gb
It has to do with the way computers count. Computers count in binary where we count in decimal.
Hard drive makers list there drives capacities in the decimal format, where windows lists it in it's binary format.
Wikipedia has a good explanation.
Also, the drive may have some preinstalled software on it that could be taking up a bit of space (it's usually not much).
May 15, 2008 | SimpleTech 320GB SimpleDrive External by...
SimpleTech 320 gb. Code 10 Problem
i doubt you can do anything about it. Code 10 is a hardware failure, so you will have to return it and get your warrenty.
Apr 28, 2008 | SimpleTech 320GB SimpleDrive External by...
Computers & Internet Logo
234 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
