Question about Canon PIXMA iP4300 InkJet Photo Printer
USB003 Error... what is this? I'm using genuine CLI-8 for my ip4300 Canon printer...
SOURCE: Canon -ip4300 printer
I have the same problem and I tried to clean the cartridges. No result.
Posted on Jan 01, 2008
IB4G2008
  • 3587 Answers
SOURCE: Cannon IP1880 Cannot detect Cartridge
hmmm..well..you may find that new drivers help a bit.
get them here
Posted on Mar 20, 2008
SOURCE: error:u043
1st step: Press and hold the Stop/reset button for 5-10 sec then release. I
f ot working then use a Qtip and moisture (not wet) it with water. Cleans the chip gently and re-insert it back and redo the 1st step.
It work for me everytime!
Posted on Sep 05, 2008
  • 12 Answers
SOURCE: How can I dismantling printer Canon iP4300?
I just opened mine tonight after finally finding a picture of where the front tabs are!
On the back you will see slots with arrows, take a flathead and push it in the slot and push downward on the screwdriver.
Then pull the paper tray out and look here for the tabs on the front.
http://docs.google.com/Doc?id=df5t4sv5_7gnzwbtgn
I wouldn't recommend dismantling farther than this as this is pretty delicate stuff.
But you can clean your waste pads out where the head parks and make sure they are firmly in position. You can also do a general cleaning I suppose.
Big thanks to RossfroMoz for posting a link to these pics which really really helped.
Posted on Jan 21, 2009
  • 37 Answers
SOURCE: Hi there i have a problem with the Canon iP4300.
Well every advice is the same except a little altered (use a warm cotton swab to clean inside machine and on print head channels) but then it says if possible replace print head but honestly this has become a primitive Machine for turning humans into corpses - buy a new one.
Posted on Nov 04, 2010
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
My Pixma iP5200 will not recognize a Staples compatible canon cli-8 cartridge. Any ideas?
Sometimes this happens with the "compatible" cartridges, I would go back and purchase another, and if that one does not work you might be stuck purchasing the genuine cartridges from Canon.
Jul 16, 2011 | Canon Pixma iP4500 InkJet Printer
Can you tell me which cartiges I need for my mx700 cannon printer,fax,copier
The Canon mx700 printer uses four (4) cartridges: PGI-5 (Black), CLI-8 (Cyan), CLI-8 (Magenta), and CLI-8 (Yellow). The colors all have the same cartridge number so you will have to specify which one you want.
I hope this helps! Good luck!
Feb 15, 2011 | Office Equipment & Supplies
Canon pixma ip4300 black ink refill. BK and PB
The correct order of install a ink tank (From Left to Right):-
1. CLI-8 Black
2. PGI-5 Black (pigment)
3. CLI-8 Yellow
4. CLI-8 Magenta
5. CLI-8 Cyan
Else you can visit this link and type "correct order of ink tank" in enter your question space.
Good luck...don't forget to rate the solution.
Feb 22, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
How do I direct my Canon ip4300 Printer to no longer print from the normal black 5BGBK cartridge (empty) but to print from the 8BK (full)
You can't because CLI-8Bk ink cartridge is use only for photo printing.For text, document or gray scale printing the printer use PGI-5Bk.You need to replace your empty PGI-5Bk.
Oct 19, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip4300 partially printing ut not fully
Try to uninstall then reinstall the printer driver, as this might be software related cli-8c
Aug 18, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
PRINTERS
try with another cartridge
Sep 03, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
249 people viewed this question
old marine
old marine
