Question about Dryers
Will not heat while running gas kenmore all cycles run but no heat
  • 10,319 Answers
First remove the vents ductwork totally and clean if neccessary. The dryer has a moister sensor that shuts the heat off. If the vent is clogged full of lint it will shut down causing your problem. If the vent has a clean flow through it the sensor is at fault
Posted on Apr 30, 2010
Kenmore Gas Dryer not heating
Find the gas solenoid and tap it with a hammer while the dryer is running, if the heat starts then the solenoid should be replaced.
It is usually behind an access panel along the bottom of the unit.
Jan 09, 2014 | Kenmore 63942 Dryer
Heat turns off while clothes still wet
change the gas coils on the gas valve by removing the 2 screws holding the bracket for the coils,remove the wire harnesses to each coil,dont worry one coil has 2 wires the other has 3 so quite hard to reverse
Jun 16, 2012 | Kenmore HE5
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Dryer just stopped running during cycle and
your heat sensors or your duct is clogged unplug, cutoff gas if you have it. disconnect the hose clamp remove rear panel remove lint by picking light brushing vac.remove screws in duct reconnectwith foil tape hoseclamp, remove all kinks slopes,and crushes. karl
Oct 28, 2009 | Kenmore Dryers
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
MY 10 YRS OLD KENMORE GAS DRYER HEST AT FRIST, THEN JUST RUNS AN
The timer has probably failed, a common problem. Easy to replace.
Jan 20, 2009 | Kenmore 73952 Gas Dryer
My Kenmore gas dryer wont heat up.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor READMORE
Dec 29, 2008 | Kenmore 73952 Gas Dryer
Kenmore 72602100 gas dryer runs but no heat
gas dryers would have an igniter to start the flame. check it first to see if its still ok. be carefull in handling them, they are very fragile. check also for availability of gas. could have a closed valve.
Jan 30, 2008 | Kenmore 63942 Dryer
Dryers Logo
Top Dryers Experts
