Question about Kenmore Elite 45986 Front Load Washer
My washer keeps shutting off and flashing 11F
  • 1,998 Answers
Serial communication error communication between the central control unit and the motorunit cannot be sent correctly
check wire harness connections to the MCU, the motor,and the CCU
check the drive system for any worn or failed components
check MCU
check motor
check wire harness
Posted on Apr 30, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Washer blinks 11F
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Kenmore elite washer flashes 11f what does that mean
Hello there and welcome to fixya
F11 is a serial communication error. Could be as simple as a loose or faulty wire harness, bad drive component or more complex like a failed MCU, CCU or even the motor. I wouldn't rule out the door lock assembly either. There ain't a whole lot left in these machines!
If you have a multimeter i would check the wires to see if there is a 0 continuity reading on the door switch if not unplug the wire harness and then leave sit for at least 30 min to allow the computer to reset itself then plug it pack in and plug in the machine and try again ok
Please let me know how it turns out i can give you step by step instructions if needed ok
Best regards michael
Mar 30, 2012 | Kenmore Washing Machines
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
Clean light keeps blinking...how do i reset?
it's telling u you have a fault but to clear it just press ur start button until the washer beeps then shut the door and leave shut until the aplliance stops. it will be ready to use. The flashes are usually intermittant i.e 3 quick flashes then a small break then 3 flashes again this process will repeat over and over. Count the flashes and let me know the amount i'll look at the fault for you
Hope this helps
Mar 19, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Hotoint WMA34 door light keeps flashing and machine wont start
The light flashing usually indicates that the door is not closed securely. this can be caused by a weak or broken door handle spring.
If you are satisfied that the handle is o/k, then the other possibility is that the control module has a blown track, this can be accessed by removing the top cover.
Hope this nhelps.
Jan 15, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Washer stops in middle of load and flashes F11.
this is not good . F/11 CODE serial communication error . the communication between the central control unit (ccu) and the motor control unit (mcu) cannot be sent correctly . now that sounds bad . don't panic!! ck the wir harness connectors to the mcu ( motor ) and ccu ( program panel . something is loose/ also ck the drive systen for any worn of failed components .belts/pulleys/ leakage.. ck mcu/ the ccu/ ck motor/ ck wire harness. -hope this will help . (look for loose connections this is most common.. mm
Dec 02, 2009 | Kenmore Elite HE4 Electric Dryer
11F
error code?
Oct 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
INDESIT 1000 DOES NOT START
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
If this doesn't work you may have to replace the EMW. Should cost you around 60$
May 23, 2008 | Indesit W 123 Front Load Washer
11F ERROR
Door lock sensor broken/need to replace.
Aug 27, 2007 | Kenmore 43142 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
110 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
