Question about GE Security Simon 3 Wireless Home Security System
My simon security systems says sensor 1 failure, but it beeps when the door is opened and closed. plus another door sensor has just started the same thing...again if you open the door, the system will say, so-so door open.
    New Friend:
  • 74 Answers
Sounds like the tamper switches may be going out.
AlarmProfessor.net
Posted on Aug 23, 2010
I have a GE Simon Security System and I recently moved a door that had a sensor on it. Now that sensor shows as 'Open' and I can't get the system to reset. Any suggestions?
You could try taking the sensor out of the system and try reseting from there. Or Virtually close the sensor. To do this point the senor sender at the sensor receiver. The reset system. If, this sensor is not being used you could tape the receiver and sender together.
Hope this helps.
Apr 14, 2011 | GE Security Simon 3 Wireless Home Security...
Getting status message "module 1 failure"
Contact me and I will tryto walk you theough your problem.
Alarmprofessor.com
Jun 24, 2010 | GE Security Simon 3 Wireless Home Security...
I have a GE Simon XT. I arm the system. When I return several hours later, the front door doesn't beep when I open it. I have to close/open it again to register. Front door is Sensor 1, Group 10. What...
Can I assume it is a wireless contact we are talking about?
1.) Low battery in tansmitter. Does your keypad display a low battery trouble? If so, ensure you put system in test before replacing battery as not to generate a tamper alarm when opening contact.
2.) Relay in transmitter is sticking. Replace wireless contact.
Stewart
May 26, 2010 | GE Security Simon 3 Wireless Home Security...
Ge simon 2 alarm no longer beeps after battery replaced
Probably knocked off the clip on the piezo. Open the box and make sure all plugs are plugged into the circuit board.
AlarmProfessor.net
May 20, 2010 | GE Security Simon 3 Wireless Home Security...
Sytem will beep every three hour or when we open the main door
Check batteries in patio door are in correctly and are good. I know you said you changed them all. but if batteries are in correctly and are good try taking them out again waiting 20 sec putting them back in. If they are bad or low most likely a bad sensor shorted the out. replace part.
Jan 21, 2010 | GE Security Simon 3 Wireless Home Security...
Battery low sensor failure on Wireless Simon ADT
the sensor seems to be malifunctioning and will have to be replaced
Sep 20, 2009 | GE Security Simon 3 Wireless Home Security...
Sensor failure Simon 3 wireless home alarm
the sensor is going out, i would switch it out with another one in your house and see if the problem follows it there.
Sep 02, 2009 | GE Security Simon 3 Wireless Home Security...
Get six beeps
You are getting a trouble beep, you can disable them for 4 hours by pressing the status button but you need to perform a sensor test. Open the panel and hit the test button, it will begin calling out sensors, open the doors and it should let you know that they are open. You probably need a battery in a sensor.
Jun 28, 2009 | GE Security Simon 3 Wireless Home Security...
Beeping at random times through the day
You are getting trouble beeps, every time you press status you delay the alarms for 4 hours then they begin again and beep every minute. You need to run a sensor test to find out which sensor has a problem. Open the panel, enter your code and press the test button, it will begin scrolling through the sensors. Activate each sensor until it stops, if one doesnt work it will keep asking you to activaate it. You probably have a dead battery in a sensor.
Jun 23, 2009 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
347 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
