Question about Xerox XG-91D 19" LCD Monitor
NO PICTURE MY XEROX XG-91D JUST STOPPED WORKING. NO PICTURE. CHECKED IT WITH ANOTHER COMPUTER AND IT IS DEFINATELY THE MONITOR. IS THERE A FUSE? ANY WAY TO FIX IT? THANK YOU ED N
  • Xerox Master
  • 1,684 Answers
These are great monitors but the power supplies have a bad habit of failing. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/xerox-xg-91d-monitor-repair/ That shows what goes out, how to get to the boards and a full parts list to do the repair. If you don't want to do the repair yourself we do offer a repair service, that information can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/ If you have any questions please let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Apr 30, 2010
My Xerox XG-91D LCD Monitor start, display briefly (about 1 or 2 secs) then goes back. any solution in this case? mention that i use with a dvi-i adaptor on a vga graphic card. thx
I would try VGA to VGA hook up first to narrow down the problem before start taking the monitor apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). See example of failed monitors to get some ideas of what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 01, 2010 | Xerox XG-91D 19" LCD Monitor
Xerox XG-19D LCD monitor goes black in 5 seconds
You may also have to check the IC/Transistors Inverter transfomer drivers, also should Ohm out the resistance of the transformers.
Mar 18, 2010 | Xerox XG-91D 19" LCD Monitor
Flat screen monitor is dim, no back light
Check to see if you do have 12vdc feeding the Inverter board, check the power supply for bad caps also. The inverter will have surface mounted fuses also, check them also. See example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 17, 2010 | Xerox XG-91D 19" LCD Monitor
My Xerox XG-91D has gone totally black. No leds light up when I plug it in. The power supply is separate from the monitor itself. The power supply led does light up when I plug it in so I know that it is...
This could be a back-light problem, it can be caused by a faulty inverter board which supplies high voltage to the CCFL lamp or the CCFL lamp is faulty. The CCFL lamp is a mini fluro tube.
Check LCD Parts for service, parts, and DIY info - click on this link to their WEB site :-
www.lcdparts.net
Oct 25, 2009 | Xerox XG-91D 19" LCD Monitor
I have a xerox XG-91D and when i power it up there is no picture and the green light flashes. how do i fix this?
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jun 05, 2009 | Xerox XG-91D 19" LCD Monitor
The connector on the monitor is different than my computer how can it be hooked up the monitor is a xerox xg-91d
Most tech stores have adapters for this kind of issue. Try BestBuy, CompUSA, or Radio Shack. I would call first and describe what two ends you need the adapter for, i.e. 15-pin male --> 15-pin male. If you are trying to connect an Apple device with a PC device, they have adapters for that too.
Mar 31, 2009 | Xerox XG-91D 19" LCD Monitor
Compatible with macbook?
Yes. if the macbook has DVI out. Do you have the correct adapter? DVI, you can't use the VGA adapter, you need the appel DVI out adapter.
Oct 04, 2008 | Xerox XG-91D 19" LCD Monitor
Logic board for xg-91d serial number E98Z5501032U
I can repair your Main logic board. I do repair work on ebay. my I.D. ecking767. Or search for Xerox under Computer and Networking
Nov 12, 2007 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D
Faulty capacitor(s) has ben mentioned by a computer repair man elsewhere in these solutions. I returned mine to the factory and was told they replaced an 'inverter' ?
Oct 17, 2007 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19 in
it look like you need an inverter
Oct 11, 2007 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19" LCD Monitor Logo
661 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
Outback Jack
Outback Jack
Steven's...
Steven's...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
