Question about Samsung CLX 3160fn All-In-One Printer
Cant get out of "scanner lock" mode...help! - Samsung CLX 3160fn All-In-One Printer
    President:
  • 524 Answers
To unlock the scanner press stop/clear.
Let me know if that work for you also if you have any questions or concerns.
Thanks.
Posted on Apr 30, 2010
Brother 750e making juddering sound and switching into satety mode, help!!
satety? Do you mean safety? This sounds like the scanner is in a locked mode or hung up. Usually on any all in one printer there is a way to lock the scanner when moving, look under where the paper comes out for a small knob or switch with a lock/unlock picture and check to see if it accidentally has been bumped to the locked position. If the scanner can't move then it will give an error so nothing is damaged. Hope this helps.
Dec 22, 2014 | Brother Office Equipment & Supplies
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
CANT TUNE IN MY SCANNER
put your bc72 in program mode.. hit you e button your enter button..but first put your scanner in function mode... then hit your enter button this will put your scanner in program mode and you can start entering your frequencies into it....if you have any problems biddy mac you can email me at randymarr570@msn.com................
Jul 02, 2011 | Uniden BC92XLT Handheld Scanner
I have a Scanner I purchased from Radio shack and My niece played with it and locked every channel out and I cant get anything on it it doesnt say what kind it is but the code on the back of it is c101153...
It's impossible to give you a definite answer without knowing the make and model of your scanner, but if your display is showing a key or a lock, look for a key that has a symbol that looks like a key or a lock. With the scanner ON, press and hold that key until the display symbol clears. I hope this helps.
Bill B.
Listening in since the 60's
Dec 19, 2010 | Uniden BC60XLT-1 Handheld Scanner
Got it on locked out some how now cant get it to do anything..help plz
Hi, my name is John. Press the lock button, the K/L will be removed from screen......hope this was very helpful..Rate this solution on the four thumbs-up....... John
Sep 12, 2010 | Uniden BC60XLT-1 Handheld Scanner
I cant get my 350a to lock in on a channel when its scanning in the private mold.it will try sometimes but wont hold them. I can push the hold button and hear crystal clear in the private mold. help...
If you haven't already done so, while scanning in the PRIVATE mode, turn the SQUELCH control down slowly until scanning stops and you hear a hissing noise. Then turn the SQUELCH up slowly until scanning resumes. This should set the threshold so that the scanner will stop on an active frequency.
BillB
Jan 18, 2010 | Uniden BC350 Base Scanner
Sharp AR-337 COPIER SCANNER LOCKS UP
Do you know how to get into the simulation mode
Like Clear ,exposure mode, clear , interrupt, are you familar with the service manual procedures ?with Sharp, are you an independant dealer. ? into simulation mode and run the Scanner mode, make sure it run back and forth ok, lubricate the track, if it gets stuck it will produce and error or stop running.
Before i can help you I need to know your expretise.
Mar 08, 2009 | Office Equipment & Supplies
BC72XLT program/scanning problems
1. If you mean on "bank" of channels, then you have locked out the others. To unlock them, place the scanner in "scan" mode & press each button that corresponds to each locked out bank until all are "on", as indicated near the top of the LCD. If you can't scan "bands", meaning all frequencies between 25-54, 118-174 & 406-512 Mhz, you may be stuck in the "capture" mode. Let me know if this is the case (not likely) & I'll coach you through it.
2. No.
3. No.
Sep 29, 2008 | Uniden BC72XLT Handheld Scanner
Cant find reset button inside scanner
There is a lock/light key at bottom left hand corner of buttons hold that down until it beeps and the buttons should be unlocked
Jul 27, 2008 | Radio Shack Pro-82 Scanner
Stuck on scan mode
Hi, It sounds to me like your keypad is locked. Pg 63 of your manual.
***using the keylock ***
Once you program your scanner, you can protect it from accidental program changes by turning on the key lock feature. When the keypad is locked, the only controls that operate are FUNC, key , SQ, and VOL. You cannot activate the keylock while you are entering a frequency into a channel. To turn on the keylock, press FUNC then key . Key locked appears for about 1 second. Key locked appears when you press any key after locking the keypad.
To turn off the keylock, press FUNC then key . The scanner beeps three times and Key unlocked appears.
The only other choice I see if that does not work would be to initialize it. Pg 84 of your manual. Hope this helps you,, Mechanic
Jan 04, 2008 | Radio Shack Pro-97 Handheld Scanner
Samsung CLX 3160fn All-In-One Printer Logo
79 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
