Question about Kenmore 15121 Built-in Dishwasher
Kenmore Built In Dishwasher
The dishwasher that we have drains up at sink level
We have cleared obvious obstructions on inside screen, upper and lower
screens - they are clear
I have triend blowing air through drain hose. No air went through the hose
the hose going from the Y valve to the garbage disposal is clear
The garbage disposal is new and there are no obstructions at the connections
in the garbage disposal - it act as tough there is an obstruction somewhere and I can't find it
I was told there was a plastic obstrucftion in the garbage disposal - I cannot find any garbage disposal obstruction
I replaced the plastic Y valve at the kitchen sink
HELP!
Dapper Dan
    President:
  • Kenmore Master
  • 2,651 Answers
The obstruction they talk about in the disposer, its where the connection for the d/w drain is made, there is a "knockout" plug within the drain line connector( in case you dont have a d/w) that would need to be removed before the d/w will drain. can be popped out with a good smack with a screw driver, the plastic knockout will land within the disposer. disconnect power and remove the plug, it will not break up and wash away
Posted on Mar 25, 2008
My Kenmore dishwasher does not drain out, What could be the problem?
No drainage, or poor drainage issues are usually caused by either a failed drain pump, or the sump area under the sprayer is clogged with debris. The sump is the area at the bottom of the tub where water collects on the initial fill. A wash pump cycles the water throughout the wash cycle, followed by the same water being drained from the unit by means of a drain pump. This area is usually covered by a coarse screen and fine screen to prevent debris from accumulating. But, over time, some debris may still get past the screens and collect in the sump. This usually results in poor cleaning results due to restricted water flow through the spray arms, and poor draining.
I would recommend you remove the lower spray arm and screens and check the sump area for obstructions. If the unit still has standing water inside, use a wet/dry shop vac to drain. Remove the drain line from your sink and pull a vacuum on the end of the dishwasher drain hose. If the water drains freely from the unit, then you probably have a bad drain pump. If the water will not drain, you have a clog somewhere. Check your drain lines and pump for obstructions.
If you have any questions, please post back with a MODEL NUMBER. I hope this helps you.
Aug 15, 2011 | Kenmore Dishwashers
Dishwasher won't drain. I made sure the sink drain were clear I don't have a Air Gap. Is there a way to check the drain inside the disherwasher. It started a couple days ago
I would check for obstruction in the drain hose.Take the drain hose off the garbage disposer hold it as low as you can over a pan or bucket and see if the dishwasher will drain centrifugally.If it does I would assume the pump is bad or disconnected.Possibly a utensil jamming it.
May 07, 2011 | GE 24 in. Profile PDW7800 Built-in...
The dishwasher has been working perfectly until recently it's not draining and water is remaining in the basin of the unit.
need to be sure the filter in the base of the dishwasher is clear of anything that would keep it from draining such as a screen filter. also need to check the hose that drains to the sink is clear. from there it is most likely a pump or timer issue.
Dec 17, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
The GE Profile Dishwasher does not drain completely. The bottom drain shows no obvious clog and the screens are clear. The overflow drain in the back of the washers the only reason the dishwasher does not...
Uncouple the drain hose connection under the sink and use a wet/dry vacuum to **** out the drain hose and the stub on the sink drain plumbing to clear any possible clogs. There may be a blocked check valve near the pump that might have to be cleaned or replaced. Check the hose itself for any kinks or collapsed section. There might be a damaged drain impeller on the pump. Hope this helps!
Mar 11, 2010 | GE Profile PDW8400J Built-in Dishwasher
Will not drain after final rinse
Check inside the dishwasher and clean out filter screens then Check the drain line between the dishwasher and sink for clogs. If all clear then the pump has gone bad or shorted out and the pump will need to be replaced.
Oct 08, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher doesn't drain fully
Hello. Are you using liquid or powdered soap? In some models liquid soap will foam up and the drain motor can't pump out bubbles. Foaming can also happen if you pre-clean your dishes with liquid soap used for washing by hand. If it is foaming, you can poor non-dairy creamer or cooking oil into the bottom of the unit while it is in the wash cycle.
If foaming isn't a problem then the water level switch may be bad, the pump may be not pumping out as quickly as it should or you may need to take the hose off completely to make double sure that there isn't anything in it.
Did you check the air-gap next to your kitchen sink faucet. If you don't have an air-gap it may be hooked up to the garbage disposal and if you don't have a high loop in your drain hose the water can run back into the dishwasher especially if the disposal backs up.
Dec 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Oct 30, 2008 | Maytag 24 in. MDB7650AWS Built-in...
Dishwasher
Check the drain hose and sink drains for obstructions. Check your disposal make sure it is clear if you have one. If drain lines are clear, then you may have an obstructioin in your pump. clear obstruction and it should work properly. If no obstructions are found check voltage going to pump during pump out. If you have voltage to the pump and the water is not pumping out, you will need a new pump. Good luck and I hope this helps you.
Mike Anderson
May 08, 2008 | GE 24 in. GSD5110 Built-in Dishwasher
Some model 665 DW have a check valve that is attached between the sump and drain hose that may have a blockage..... Remove the drain hose from the long plastic valve then carefully unscrew the check valve from the sump. Inspect for debris.
Jan 03, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
Sep 16, 2007 | Kenmore 24 in. 15173 Stainless Steel...
Kenmore 15121 Built-in Dishwasher Logo
211 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
