Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Fuel mix ratio for poulan counter vibe 3400 chain saw and for a homelite st-145 weed trimmer
    President:
  • 2,220 Answers
Oil Mix Ratio: (last 5-10 years)
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If me I would have the Poulan tweaked to run properly on 50:1 and use that in both. It will start easier and take much longer to carbon foul.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 30, 2010
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the mix for my Homelite 16" 33cc chainsaw?
50:1 is the fuel to oil ratio. Never use petroleum oil (engine or boat motor oil). Always use a synthetic saw oil available from home centers, hardware stores and saw dealers. The bottles are usually graduated to various ratios for a gallon of fresh gas. Always premix in it's own container and shake the container thoroughly each time just before filling the tank to prevent oil starvation. Be sure to use bar/chain oil for the chain as well, and keep the chain sharp and well adjusted. Hope this helps!
Nov 14, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
What is gas oil ratio for a 16 inch poulan chain saw
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Lou
Aug 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fuel mix ratio for poulan counter vibe 3400 chain saw; mix ratio
A different site that lists 40:1. http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/4a98e23d38cbda9b88256bf80015de57?OpenDocument
Oil mix is controversial. Some think more is better, todays saws run much faster and carbon up much quicker. Ask the mechanics at a local saw shop. I will wager they say 50:1 regardless of the age of the saw. Me too! The Echo site now says use 50:1 regardless of what is printed in the OM. It is your saw Mike; run what you want.
Lou
May 02, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Homelite ST-145 oil leaking from muffler
you are right it should be 32:1 for most homelites
Jul 19, 2009 | Garden
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
gasoline. Before operation, gasoline must be
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
I have inheirited a Poulan counter vibe 3400 it
Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then select oem poulan then poulan then saw then look at list of models you will find 3400. Have worked on one or two of the 3400 and they seem to be a fairly good saw for home use.
Apr 07, 2009 | Poulan Garden
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
581 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
