Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water on shelves
Every few days find water on shelf. Once found some under left vegetable bin. Don't know age of refrigerator.
  • 26 Answers
It sounds like the defrost drain is plugged. It is behind the back panel inside the freezer. Either defrost the whole unit, or use hot water to defrost the drain line. Be careful it is located right under coil and the fins are sharp! My knuckles have been cut many a time! Good Luck
Posted on Apr 30, 2010
Have a Samsung RF217ACRS refrigerator that is collecting water in the left bin? I do have an ice maker.
the defrost drain is stopped up...the simplest way to start is to remove food, unplug frig and open both doors for 24 hrs. a fan blowing into ref will help this process. after 24 hrs remove the shelving so you can get to the back panel... there will be 3 screws 1 on the bottom left and 1 on the bottom right corners, the 3rd is located about 2/3 of the way up the panel in the center. this screw has a square plug covering it.. after screw removal "pop" the cover being careful of the wiring at the top, after unplugging the 2 plugs set panel to the side out of the way.... now you are looking at the evaporator, just under the evap you should see a hole, this is the defrost drain.. if there is any ice in the trough remove it, with hot water if need be. once the drain is open pour 2-3 glasses of hot water down the drain to flush out.. if water wont pour through drain, I use air pressure to clear drain, if u don't have an air tank you can use a hose that you blow through to clear drain.......I hope this helps.......Ken
Sep 15, 2014 | Samsung RF217ACRS Bottom Freezer French...
Where is the drain hole for this model
Good Afternoon Friend,
I understand that you are looking for the drain hole on your Frigidaire refrigerator, model# FFHT1725PS, due to water building up on the shelves inside your refrigerator. There technically is no drain in your refrigerator. There is a drip pan, which collects water from the condenser underneath your appliance. There are some possibilities that are causing the water to build up on the shelves. First, make sure that all containers are covered. Condensation can evaporate from opened containers and create water on the walls and shelves. Secondly, make sure that the drawers that have your fruits and vegetables are completely closed and set to the correct setting. Fruits and vegetables are full of water. Thirdly, check to make sure that your doors are closing and sealing correctly. Moisture can come through an open door or a door that is not sealed correctly. Lastly, if it is hot and humid, make sure that you are not going in your refrigerator many times and holding the door open as well. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire FFHT1725PS 16.5 cu. ft....
Ge model number tbx21jaxerww. Water collecting under vegetable bins
The water building under the veggie bins problem is usually a result of the drain under the evaporator coils being clogged with either ice or debris.
The get to the drain, the shelves and sometimes the bins will need to be removed, then the back panel will need to be removed. There usually are a few screws on each side that hold the panel in place...
Then look for the drain right under the coil....if possible run a wire down the hole to make sure it is open to the pan underneath.
If it is frozen then a wire can be used to keep the drain open...here is a tip about how to do that...
WaterRunning in refrigerator from Freezer
heatman101
Jul 27, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
Water is collecting on the left side on shelves and vegetable bin
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | Whirlpool Refrigerators
We have water laying on the bottom shelf every day
Under the evaporator coils is a drain. It catches the defrost water and directs it to a pan above the compressor where it evaporates. The drain clogs and water cascades down the back wall ending up under the crispers. Get a shop vac and open the drain.
May 17, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Water leaks in from freezer. eventually filling vegetable bins and falling out onto floor. Ice formation near back top shelf and other shelves. Is their a simple fix?
Maybe, Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Oct 27, 2009 | KitchenAid KSRA25ILSS Side by Side...
Water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Too cold in vegetable bins
Air flow ports adjusted correctly? Air flow fan running? I once had a bad temp sensor on the freezer coil that would not let the fan run.
May 29, 2008 | Amana ABB2227DE Bottom Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
200 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
