Question about Maytag EPICz 3.7 cu. ft. Washer
Seal is ripped
Hi! I have a maytag Epic Z front load washer. There is a piece of the seal that has ripped off. Water leaks out when using. Can you buy a new seal?
  • 5,911 Answers
Yes, the door seal (bellow) can be purchased and replaced. The following link explains step-by-step how to change the door bellow on a Maytag Epic front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The firsat three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful. NOTE: Maytag Epic is manufactured by Whirlpool, so these instructions will apply.
Posted on Apr 30, 2010
Testimonial: "Thanks so much for your help!"
My Epic Z front load is leaking water . It looks like the gray rubber on the door is the cause. The machine is only 18 months old
In the front on the bottom of the gray seal is two drain holes, make sure there is not an obstruction in these drain holes such as a small sock .
May 21, 2011 | Maytag EPIC MFW9700S Front Load Washer
Washer leaking water around front door
Check the seal around the front load door. It's possible there could be a crack along it.
Feb 28, 2011 | Maytag EPIC MFW9700S Front Load Washer
My Maytag epic z leaks water from the bottom of the machine, not sure where its coming from.
If your front load washer is leaking, the following link explains how to access the interior cabinet and what to look for:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In the majority of cases, leaks on front loaders are caused by a worn or loose door bellow. This is the gray rubber seal around the door opening. If the bellow has any rips or tears it must be replaced. The following link explains how to replace one (if required):
Replacment parts (if required) can be purchased on line at any of the following websites:
repairclinic.com
These sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites on the list also offer helpful exploded view parts diagrams to assist you with properly identifying and locating parts.
Read through the link provided and inspect the washer cabinet thoroughly. It may help to add some water to the drum.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: Overloading the washer can cause premature wear on the door bellow. In addition, using the wrong type of detergent (i.e., other than HE), or using the wrong concentration of soap can cause premature wear to the pump seals.
Feb 04, 2010 | Maytag EPIC MFW9700S Front Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
FRONT DOOR OF WASHER LEAKING
Hello. W/D here.
It's actually pretty easy to get it back on when you know the trick.
Since it has leaked on you, you may want to remove the seal off of the rim closest to the door and clean the rim and the sealing surface. The seal has a molded lip that fits on to a raised formed rim, and it gets pressed on snugly before the ring and spring are added. You can seat the seal by pressing on it all the way around with the palms of your hands.
To install the ring:
Start the ring 180 degrees from the spring, placing it in the groove behind the seal face. (You want to make sure that the seal is pressed back into place first). Work the ring on around the seal, until you get to mostly just the spring remaining. Now lever the spring over the lip and into the groove, using a small screwdriver, being careful not to damage the seal with the screwdriver.
Best regards, --W/D--
Aug 20, 2009 | Maytag EPIC MFW9700S Front Load Washer
Water Leak from the Front Door of our Maytag Epic MFW9700S
The water leaking is most likely the gasket. It may have a little rip or something making it not seal. Im not sure about Maytag but on our GE we had to slide the the top back to remove some screws then (I believe to was for the control panel) Then we removed screws for the door and the front of the washer. When that was done you have to remove a round clamp that holds the gasket on. Then replace the gasket.
My suggestion is to have a appliance repair come and do it. Its a pain to do, at least it was for me.
Jan 28, 2009 | Maytag EPIC MFW9700S Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Maytag EPICz 3.7 cu. ft. Washer Logo
1,236 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
