Question about Garden
How to revive a Black & Decker PS145 battery? Mine seems to take a charge ok but quickly looses its strength even if it is not being used. I beleive this is a NICAD type battery, therefore it builds a memory the more times it is charged, but I've also heard that these batteries can be rejuvinated. Do you have any information on how to go able doing this? Thanks!
  • ka9ppa Apr 30, 2010
    Yes! Very helpful & very appreciated. A Ham Radio Convention is coming up and now I have something to add to my shopping list for the Flea Market!
    Thanks very much for the help!!! :)
  • 12,061 Answers
Ok, I make these pack of batteries all the time, it is quite simple really, you just need, Suitable Size, 1.2V Ni-cad's with Solder Tabs, (All Batteries are standard sizes, AA, AAA, B, N, C, are some of the sizes, all 1.2 Volts but differing mA/Hours, get the highest mAH you can get in that "Range". Then, simply join them up as the "Old" one, is wired up, usually they are all in series, but NOT always, simply draw out the existing batteries circuit, paying strict attention to Polarity. You can get the batteries from eBay, and they are quite inexpensive. Another way I do to "Rescue" a "Pack" is to use another good power supply, Current Limited, that can supply the "Charging" Voltage but at an Amperage of about 1 Amp. Now connect up the battery Pack to the Power Supply, and charge it up at about, 1/4 - 1/2 Amp for say Overnight, ensure they do NOT get too Hot, when charging. When finished, then use a suitable light bulb, and put it across the terminals, and leave on until, flat, and then leave it another hour or so, Now charge the Pack, up again, this time, at the end, you will have reconditioned your battery pack. Sometimes during this procedure, the batteries may "Fail" usually one or more go open circuit, this is GOOD, as now you have found your Faulty Cells, Now you can either just replace the faulty "Cells" in the assembly, OR simply make a whole new pack. Just make sure that any "Electronics" inside the batteries, is Transplanted as well, sometimes there is a Thermal Fuse, this can simply be bypassed with a wire, or replaced, as you wish. Anything else is just wired back in, as it was.
Posted on Apr 30, 2010
Is it my Black and Decker PS185 18 Volt Battery Charger #418352-03 or my ps145 power pack
You need a volt meter, They are cheap and it will come in handy down the road. The volt meter will tell you if your charger is the problem or the battery has went to battery heaven.
Feb 14, 2013 | Black & Decker Black And Decker PS185 18...
Where can I get a battery for Black & Decker Drill CD 1000?
This will be a suggestion...but for mine I bought two 18650 LiFePo4 cells (3.7V each) and replaced the original NiCd Batteries. It has been working for many years now, since the original batteries expired and stop working in 2002 (I bought the CD 1000 back in 1994!!!!!). You have to use a special charger for the new ones but they stay charged a lot more and the drill has more torque.
Jan 10, 2013 | Black & Decker Drills
Black & Decker battery operated weed eater/edger not working at all.
you probably need to take the base apart ,mine had a loose wire on the motor on the end of the shaft,about ten phillips head screws ,there is one screw on the gaurd,good luck
May 31, 2012 | Black & Decker Grasshog 12 Inch 18 Volt...
Batteries wont hold charge can i revive them please, and how do i do it.
It is a sealed unit and not worth trying. Go to ebay etc or a Black & Decker stockist for another battery
Dec 01, 2010 | Black & Decker Black and Decker 18V...
Short battery charge
The B & D MM575 mower is not battery operated nor is it cordless. CMM1200 CMM1936 CMM1836 are the currently available cordless mowers. You can buy a battery from B &D, they list it here:
http://blackanddecker.com/ProductGuide/Product-Details.aspx?ProductID=22989
tom
May 10, 2010 | Black & Decker Black and Decker Mm575 18"...
18v battery lasts 10-15 minutes after the charge. How long should I charge it for to get full usage?
Black and decker older batteries don't keep a charge. Very poor quality. You can't get them to work any better than they do. You need to replace will the new ones they sell, made better. But cheaper to buy new tool with batteries included.
May 02, 2010 | Black & Decker PS145 18V Battery
HOW DO YOU REVIVE A BLACK & DECKER NICID 12V BATTERY FOR CORDLESS HEDGER?
Hello. No problem if you have a battery charger and a few minutes. Here is the link to the step by step method. read on http://www.ehow.com/how_6190591_recondition-nicad-battery.html
Joe
Apr 06, 2010 | Black & Decker Garden
Describe your Black & Decker Black
If it is not 2 years old, it is covered under warranty: http://www.blackanddecker.com/CustomerCenter/Warranty.aspx
Sep 12, 2009 | Black & Decker Black And Decker FS24C...
Won't charge fully
If your warranty has expired, you're best off buying a new drill. Replacing batteries will quickly add up to the cost of a new drill.
I know they cost a lot more, but, if you want something that will last a lot longer, look at a Milwaukee, DeWalt, Makita, Bosch, Hitachi for your replacement. Milwaukee actually guarantees their LiIon batteries will last 1,000 charges or longer.
May 24, 2009 | Black & Decker 14.4v Cordless Lithium...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
