Question about Garmin nuvi 1390T Car GPS Receiver
Garmin 1390t freezes at loading maps - Garmin nuvi 1390T Car GPS Receiver
  • skeeterb66 May 24, 2010
    what if the device goes straight to loading maps then the "do you really want to erase all data" screen comes on but it won't respond to your touch screen answer "yes"?
    President:
  • 1,851 Answers
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Posted on May 08, 2010
  • helpme12345 Sep 29, 2010
    why wont it let me select yes?
For the 1390:
  1. If the device is already connected to the computer, press and hold the power button to restart the device. If the device is disconnected from the computer, start with the device off and press and hold to power on.
  2. While the device is booting up, press and hold the upper-left corner of the screen for 30 seconds.
    If the device is already plugged into the USB, your computer may indicate that it has recognized the device is plugged in. At that point, release the screen.
    If the device is unplugged, the calibration screen may display. Now, plug the device into the computer's USB port. A green status bar will start loading as the device prepares to connect to the computer.
  3. Once the status bar indicates full scale, the computer symbol will show on the device's screen indicating that it is ready to connect to the computer. If you are not already plugged into the computer, then plug the device in via USB cable. This should enable recognition between the computer and the device.
From here you should be able to access the Garmin device, properly recognized by your computer as a GPS device. You will also be able to use the Communicator plugin on the Garmin site or the Webupdater software.
Posted on Aug 19, 2012
Hi, I am having the same problem and can't reset ( does not allow you to select yes or No to erase data. Also the USB connection does not recognise the device at all. I have had my 1390 for 13 months, how is it that everyone can have this same problem with every model?? Garmin keep their servie Dept in business??
Posted on Sep 06, 2010
Garmin nuvi 1390t won't read or recognize microsd
The 1390t works with microSD cards. Your 8GB card is actually a microSDHC card. While it fits into the slot, it will not work in older devices.
You need to go with microSD cards, 2GB and smaller.
Feb 09, 2012 | Garmin nuvi 1390T Car GPS Receiver
Tip
Garmin Nuvi 1390 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1390 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
___________________________
Garmin Nuvi 1390 Manual Download
Garmin Nuvi 1390 QuickStart Download
Garmin Nuvi 1390 Favorites Backup
Garmin Nuvi 1390 Hard Reset
on May 15, 2010 | Garmin nuvi 1390T Car GPS Receiver
Microsd card won't read
You need to use a microSD card, not a microSDHC card. microSD cards max out at 2GB, anything larger is a microSDHC.
Garmin nuvi 1390 stuck on 'Garmin' screen. No maps loading etc.. Also did the reset process with no luck
Try running the Garmin WebUpdater.
Download and Install WebUpdater.
If the WebUpdater does not work, you may have to contact Garmin support.
Jul 23, 2011 | Garmin nuvi 1390T Car GPS Receiver
How do I restore the qwerty keyboard to my 1390T?
Contact Garmin at https://support.garmin.com/support/searchSupport/escalateForm.htm . They will send you a zip file with the complete keyboards folder and directions to restore to your unit. Mine was missing altogether after I lost the maps too. It was easy to copy to the gps unit and now the qwerty keyboard is back again.
Jun 17, 2011 | Garmin nuvi 1390T Car GPS Receiver
My husbands garmine nuvi 1390 is stuck on the loading maps screen. We have tried shutting it down but it stays on the map screen
PRobably needs a firmware restore. Go to Garmin Reset. If it fails you need a new logic board. If they don't give you a new one under warranty, are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult.
May 27, 2010 | Garmin nuvi 1390T Car GPS Receiver
Garmin nuvi 1390T Car GPS Receiver Logo
1,923 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
