Question about Whirlpool DU1055XTS Built-in Dishwasher
Dishwasher was running and power went off
My dishwasher stop working and I checked the fuse and it was not blown. I went to my basement and they junction box the dishwasher is hooked up to has power. I think the thermal fuse is bad but how do I check to see if it is that? Also if it is that how do I install it/
  • sperry85 Apr 30, 2010
    I did that and there is no power going to this unit but the power plug has power going through it.
  • Rick Ead
    Rick Ead May 11, 2010
    first undo the lower panel on the bottom of the machine and in the right corner check to see if you have power going to the unit
  • 26 Answers
It is mounted on the main control board inside the door. It is a white square on the side of the board housing. To check it you will need an ohm meter. If it is bad there will be no continuity. Make sure the power is off before you do this! Good luck.
Posted on Apr 30, 2010
Kitchenaide dishwasher KUDS25SHBS1
I have listed COMMON problems / reasons why a dishwasher won't start..
The thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Dec 15, 2013 | KitchenAid Dishwashers
My 2yr old whirlpool dishwasher model# DU1145XTPBA, ser# FU3026019, 2.7 amps, type# 5750-0 has stopped turning on. I never had any trouble out of it and now it won't turn on. I thought maybe a fuse...
It is possible the thermal fuse located in the control panel has blown.
See item 5 in this diagram. You could attempt to replace it.
make sure the power is disconnected when you are working on the dishwasher.
Hope this helps.
Jun 21, 2011 | Whirlpool Dishwashers
Miele G 2630 stopped working. It started and then just stopped now no power
Hi
The power issue with the Miele G2630 dishwasher is due to a blown fuse inside the dishwasher or due to faulty main board of the dishwasher. However, before checking internal components we can first reset the circuit breaker, make sure it is a 15 A breaker. If the breaker is fine then you'll need to disassemble the dishwasher. Try and dis-mantle the dishwasher from its place, before this remember to turn off power and water supply. And also check for the drain hose. After the dishwasher is dismantled, you can remove the back panel of the dishwasher and check for the blown fuse and also check for any loose connections on the power supply board. Inspect for burnt components on the main board.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 30, 2010 | Miele G2630SCiSS Dishwasher
No power or lights in the front panel
Check the fuse / circuit breaker inside washing machine. There may be a extra control circuit fuse normally on the control PCB.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My lights on the control panel of my dishwasher just went out and I can not get it to run. Checked the panel in basement. There is water in the bottom of unit. Have any suggestions. The dishwasher is 2...
Check the power circuit for the dishwasher to make sure it is getting power. Could be a tripped breaker, or tripped GFCI. But until we know if the DW is getting power, we can't help much more than that.
Let us know what you find.
Dec 17, 2009 | Cell Phones
No power to dishwasher
Do the following:
  1. Check the power from the wall outlet or the branch circuit itself.
  2. Check for a blown fuse or a tripped circuit breaker.
  3. Check the wiring connections of the dishwasher from the house wiring.
  4. Check the door switch. Remove the control panel cover or the interior liner of the door whenever it is applicable. Replace if defective.
  5. Check the timer or selector switch. replace if defective.
Aug 30, 2009 | GE Nautilus 24" Built-in Dishwasher
No power to unit, dishwasher model DU960PWKB1. Unit was running, then abrubtly stopped, leaving water in the tub, and no power to drain or run unit. All breakers good, no other signs of problem. Help!
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 16, 2009 | Dishwashers
Frigidaire dishwasher fdb2415lf will not turn on. Was working fine, no fuse blown, not disconnected.
I have one of these modles and yesterday after it finished I noticed a lilttle green light on below the main options, a little lock that is telling me to "hold to unlock" not sure what that means, so tried this morning to "hold" nothing happened as need to run the machine, and right now there is no response. HELP!!!!!!!
May 31, 2009 | Frigidaire 24 in. FDBB944C Built-in...
Wont do anything, not even drain
Try unplugging the unit for 15 minutes then plug it back in. If that fails it sounds like the inline fuse which means you will have to pull out the dishwasher and look near the pump is blown and fuse needs to be replaed
May 26, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Just stopped working
Check the following to address this issue.
2. Door switch
3. Timer
4. Selector switch
Jul 02, 2008 | Roper 24 in. RUD3000 Built-in Dishwasher
Whirlpool DU1055XTS Built-in Dishwasher Logo
177 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
