Question about HP PSC 2410 All-In-One InkJet Printer
PRINTER SQUEAKS WHEN IT PRINTS AND NOW DOES NOT PRINT THE FULL PAGE JUST SMALL PARTS OF IT
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 30, 2010
Error message, print requests stuck in que
you might have multiple prints loaded
make sure you have the printer turned off it might load another page to be printed
you will need to open up a page you are about to print click ok
a page will open with a display print que tab
you will see all of the prints you have loaded
right click on the ones you dont need select delete
hope this helps
Nov 19, 2011 | Brother MFC 420CN All-In-One InkJet...
Unable to print or delete a document
  • 1
    Remove the cartridges from the F380 printer.
  • 2
    Position the cartridges so they are right side up and the gold leads are facing you.
  • 3
    Place a small piece of tape over the gold contact in the top left corner of each cartridge.
  • 4
    Place the cartridge back in the F380 printer. The printer automatically prints an alignment page.
  • 5
    Remove the cartridges. Place a piece of tape over the gold contact in the top right corner of each cartridge.
  • 6
    Place the cartridges back into the F380 printer. The F380 prints another alignment page.
  • 7
    Remove the cartridges from the printer. Remove both pieces of tape from each cartridge.
  • 8
    Insert the cartridges into the F380 printer. The printer prints a cartridge alignment page. Each cartridge is now recognized as a full ink cartridge.
  • Jun 16, 2011 | HP DeskJet F380 All-In-One Printer
    The page prints to a small version in top left hand corner. everything is set to A4. Have tried all settings Have tried paper feed from back and front. Unable to get it to print a full size A4 page even...
    Make sure on the Page Setup tab that the Page Layout says 'Normal-size' and not 'Poster' (poster tries to place four documents on a single printed sheet). If this is not the problem, try uninstalling and reinstalling the printer driver.
    Feb 10, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
    I have a Lexmark C522 When I print to it...the image that should be a full page prints really small on half of the page. How can I make it print what I send it?
    this problem would indicate that the printer thinks the paper is smaller than it is. check the paper size settings on the drawer if the settings are right the replace the paper size pcb
    Dec 03, 2009 | Lexmark C522n Laser Printer
    Print half of full page
    If the printer starts to print and stop in the middle check the eletricity of your place, this may have a variation. If the printer prints a half page and give you the paper, with no jam, check the cartridges and then the main board.
    Aug 13, 2009 | Lexmark X5470 All-In-One InkJet Printer
    Our lexmark Z705 printer only prints won't print black.
    Clean your printer cartridge printer maintainence program or alignment or head clean
    Jun 27, 2009 | Lexmark Z705 Photo Jetprinter InkJet
    Printer prints very small
    sound like software glitch. binary data mixed in.
    Re-install the software
    Regards
    Richard.
    Apr 21, 2009 | HP PSC 1350 All-In-One Thermal Printer
    Canon MP600 not printing on full page - in upper left corner
    I went to the Canon website and downloaded the drivers for the printer and it printed out right--on a full page.
    Feb 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
    Size of page printed small
    Check your default paper size on both the document program you are using and the printer. You could have it set for 5X7 and that's what it will figure for, even with 8 1/2X11 paper.
    Jan 30, 2009 | Canon i850 InkJet Photo Printer
    Dell printer problems
    You need to enter Page Setup under the File menu. Check that the scale is 100% and the page margins are set to 1/2 inch on all sides.
    Then, you can also enter Printer Preview, and check that "fit to page" is not set and the printer settings will result in actual size.
    Please remember to rate all solutions you receive on FixYa and thanks for using FixYa.com.
    Regards,
    Worldvet
    Aug 31, 2008 | Dell Office Equipment & Supplies
    HP PSC 2410 All-In-One InkJet Printer Logo
    57 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
