I have an ethernet hub to which my dsl modem is connected. I also have two computers on this hub so I can access the internet on both PCs. I am trying to also connect a belkin wireless access point to the hub so I can access the internet from my PSP/Wii/Xbox. Every time one of these devices tries to get the IP address, it fails. What am i doing wrong?
You should try to upgrade to a router. The main differences between a router and a hub is a router has a microcontroller and a hub does not. The router can operate at something called a full duplex which means it can send and receive data at the same time, it will also come with an additional IP address, possibly your internet service provider will only allow a limited number of IP addresses per one line. First unplug another connection and then try your X-box connection.
Posted on Mar 25, 2008
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
I just bought a dynex ethernet switch so that my daughter can plug her laptop into it and access the internet. I have a dsl modem connected to the switch. i have the switch connected to my desktop. I...
maybe you need to configure this ethernet switch or it is a password problem i have used a ethernet splitter switch to use two connect 2 computers before purchasing a router which needed to be configured
hope this helps
Sep 03, 2010 | Dynex 5 Port 10/100 Ethernet Switch...
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
How do you hook up a Dynex Ethernet Hub
If your hub has 4 or 5 connectors, connect one port to your router. This device will NOT work when connected to your cable modem, as the hub does not manage IP addresses like a router does. Hope this helps ... the remaining ports will feed internet, but not provide Internet addresses to a computer.
Nov 08, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
I have 3 PCs -> 1st have 1 Ethernet port. (this PC have a laser printer, dual core processor, BSNL board band) -> 2nd have 2 Ethernet port. (1 is Motherboard inbuilt & other is connected as NIC...
http://www.geekgirls.com/windowsxp_home_network.htm
or
http://windowshelp.microsoft.com/Windows/en-US/help/76174f4a-7522-425a-9424-324dd299265e1033.mspx
or
http://video.google.com/videoplay?docid=-4885804885278005452#
Sep 20, 2009 | ASUS P5VD2-MX SE Motherboard
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Trying to connect 4 dsl routers to 48 port switch
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Feb 24, 2009 | 3Com 2250 Plus (3C16476CS) 48-Port...
Wired router connection
To my knowledge, yes. "dial-up internet" connotes standard modem attached to a computer unlike DSL modems (non USB) that are stand alone. Therefore the dial-up internet modem should be connected to a single computer. That PC then would have to enable its Internet Sharing for others in the network to access the Internet. This is accomplished by hooking all the PCs to a single network using a hub/switch. The router can perform this function (hub), however, all the PCs in the network would have to use for their Default Gateway IP address not that of the router but that of the PC with the dial-up internet modem. Having said that, it would then be necessary to use static IP adds in all the PCs. The built-in firewall and DHCP features of the router would not be necessary.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 23, 2008 | Microsoft Broadband Networking MN-100...
NH1005
connect your broadband modem into hub. configure your broadband modem to PPPOE. then u can access internet in both pcs.
Mar 10, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Home networking
You need to go to control panel>network set up wizard on the pc which has the internet connection and when you go through the wizard amongst prompts select, allow other computers to connect through this computer and then finish off the wizard. On the other computer you do the same but, on this one select this computer connects via another computer on the network and again finish off the wizard.
Oct 02, 2007 | Acer ALW 3016 Networking Switch
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
