Question about Sony PlayStation® 3 (80GB) Console
Possible overheating i'm not sure if this is normal because it didn't do it when i first got it. The fan stars going loud after a few minutes right after i turn it on and sometimes it freezes for short periods
    Sergeant:
    Champion:
  • 230 Answers
The PS3 has an automatic feature to shut down the system once it acquires overheating. The fans installed vary on how much heat is being generated by the system to cool it down. If the screen freezes occassionally try to set the resolution to a lower setting, say downscale from 1080p to 720p as it will make the system's work a little bit lighter and generate lesser heat. Hope it works.
Posted on Apr 30, 2010
Furnace starts and ignites and fan comes on but when thermostat is turned off the gas shuts off and flame off but furnace continues to run. whu?? any suggestions?
The fan normally runs for a few minutes or so after the gas shuts off.
This removes the heat from the furnace and transfers it into the living space instead of just letting it possibly cause overheating of the furnace until it dissipates. If it is a fan that blows outside, that fan also needs to run for a few minutes to clear exhaust gasses from the furnace - to keep them from dissipating into your home.
Sep 28, 2015 | Heating & Cooling
I have a maytag dryer that sometimes when I hit the start button will start and run for only a few minutes and stop and wont start again for a while and does a humming noise when it does star why?
Sounds like the motor is going into thermal overload (Getting hot) it may be caused by the motor itself, or could be overloaded by bearings or fan etc
Jul 28, 2014 | Maytag Dryers
Running an Acer Aspire ax5900. The video card fan vibrates loudly for the first 10 minutes of startup. I'm told I need a new video card. Area is clean and dust free. Where is the best place to find a...
Your Acer Aspire, like any other desktop computer system, contains fans inside the case to help vent the heat generated by the internal components.
These fans generally operate quietly and reliably, working in the background to prevent your computer from overheating.
A fan that sounds excessively loud could indicate a problem such as overheating or loose internal components, or it could simply be a normally loud fan.
The key to differentiating between the two involves looking for additional clues from your computer.
Normal Operation
Due to computer configuration and build quality, the fans in some desktops sound louder than others.
Depending on what other brands of computers you've owned or have had experience with, the fan in the Acer may sound louder, when it's actually functioning perfectly.
The fan will run to keep the inside of the computer from overheating, so periodic runs are normal. If the fan runs for long periods or very often, you may have a deeper problem.
Fan Damage and Overheating
A fan can sound loud due to damage, such as broken blades or to a build-up of dirt that impedes normal operation.
This dirt, as well as normal wear and usage, can wear away the lubricant coating on the fan's internal shaft, causing the blades to make excessive noise as they turn. In many cases, a loud fan indicates that the computer is overheating, causing the fan to run more often than usual to try and cool the system.
Depending on the types of components and upgrades within your Acer computer, your current fan may be too small and weak to handle the heat output, and require upgrading to a larger, more powerful fan.
Troubleshooting Take note of when the fan turns on and how long it runs to determine any distinct patterns, whether if it occurs only during certain processes or programs.
Your computer's CPU generates a large amount of heat while in operation, so programs that require large amounts of CPU usage may trigger the fan more often.
Watch for additional signs of overheating, such as sudden shutdowns or computer crashes. Check inside the case for signs of other components touching the fan and causing vibration noise.
Solution
Do not overtax the CPU by opening numerous processor-intensive programs at once.
Check that all screws, cards and wires are securely fastened and away from the fan.
Keep your computer clean inside and out, to prevent the build-up of dirt on the fan blades or air vents and minimize the threat of overheating.
Apply a drop of oil to your fan's shaft to give it proper lubrication and smooth, quiet rotation of the blades.
http://www.techrepublic.com/article/quiet-noisy-computer-fans-with-a-drop-of-oil/5034842
Aug 06, 2013 | Computers & Internet
I have an acer aspire ax5900. The video card fan vibrates loudly for the first 10 minutes after start up. I am told I need a new video card. Is this correct and where is the best place to get one?
Normal Operation
Troubleshooting
Solution
The oven is not work or better say works for little be and going off. could you please help or please let me know what telephone should I call?
Hi,Everything operates normally, but the oven shuts off after varying amounts of time. This could be a faulty magnetron, bad cooling fan (or just built up dust and grime block ventilation grilles), bad thermal protector, faulty controller, some other intermittent component, or bad connections.
  • If resetting it allows cooking to resume immediately, if even for a few seconds, I would not suspect the magnetron or thermal problem as no cool down time is required. It could be bad connections in the controller or elsewhere, a marginal door interlock switch, or a controller problem. Jiggle the door to see if this will cause it to shut off.
  • If the magnetron was overheating, you would not be able to resume cooking until it cooled and the thermal protector reset. If it just stopped working (i.e., the filament opened), everything would appear normal but there would be no heating. If the magnetron were shorting, there would likely be a loud hum associated with the periods where there was no heat.
  • If it is not possible to resume cooking for a few minutes indicating that something needs time to cool off, then the magnetron could be faulty but check for the obvious cooling problems first: blocked or dirty ventilation grill. Determine if the magnetron cooling fan is operating by listening for its sound or looking through the ventilation opening in the back of the oven. If it is not, there could be a broken or weak belt, gummed up or lack of lubrication, other mechanical problems, a bad motor, or bad connections.
  • Extremely high power line voltage may also result in overheating on a poorly designed or oven where the components are marginal.
  • Make sure the stirrer fan is turning normally. Should it gets stuck, some models may sense this and shut down/restart.
Hope it helped..
Thanks for using fixya....
Oct 20, 2010 | Ovens
My 2007 Impala LS says its overheating shut off A/C the temp gauge goes all the way up then in an instant comes back down to normal
CHECK COOLANT LEVEL TO MAKE SURE NOT LOW.IF ALL LOOKS GOOD.CRANK ENGINE LET IDLE FEW MINUTES TURN ON AC MAX LEVEL TO SEE IF COOLANT FANS COMING ON.IF NO CHECK COOLANT FANS FUSE AND RELAYS.IF COOLANTS FANS COME ON WHILE ENGINE OVERHEATING THERMOSTAT BAD.IF ENGINE OVERHEATING FANS NOT COMING ON YOUR COOLANT TEMPERATURE SENSOR FAULTY.
Sep 01, 2010 | 2007 Chevrolet Impala LS Sedan New Cars
My 99 300m is overheating but the tempature gauge shows normal
i have a grand voyager 1999 and it temputure is running on the 3quater mark on the gauge is this right....
Jun 07, 2010 | 1999 Chrysler 300M
My laptop compaq 6735s will only stay on for a few minutes before shutting itself off and not working for a long time. Also, the area where the port is for the laptops charger get's exteremely hot. I don't...
This sounds like *********** board is overheating due to probably dust and fan not working properly. Try using air can to blow some of the stuff of off the fan from the bottom of the laptop but make sure you dont tip the can over while doing this because the air turns in to ice and it will mess up you laptop. If just blowing air don't work then you have to open it and clean it up.Hope this helps.
Jan 11, 2010 | HP Compaq 6735s Notebook
Dell Dimension 8400 locks up after 15 - 20 minutes of use it doesn't matter the applications that are running. The start button must be pressed and held for a few seconds to power down the unit. It will...
Sounds like an overheating problem to me. Try taking off the side of the case, and starting the unit. Pay close attention to the fans that you can see. leave the computer running, and continue to check the fans. If a fan is going bad, not working, or going to slow, then the processor will overheat, and shut off the computer. Bad fans are easy to replace, just make sure you get the right size, with the right plug. This is just one possible reason for your problem, a further troubleshooting of the unit is needed...possible bad RAM, or video card failure can cause this mysterious shut down.
Aug 04, 2009 | Dell Dimension 8300 PC Desktop
Ford winstar 1997 overheating
You should check the coolant level first. If it is low then the CTS (Coolant Temp Sensor) cannot send a reliable signal and therefore the ECM thinks the engine is cool. If the coolant level is correct then the CTS or related wiring could be faulty. The fans should come on when the A/C compressor "cycles" on, if not have your favourite A/C tech inspect the system.
Jul 05, 2009 | 1999 Cadillac DeVille
Sony PlayStation® 3 (80GB) Console Logo
120 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
