Question about LG 42PX5D 42 in. Plasma HDTV
42" LG plasma tv multicolor vertical bars
I was wondering if you could help me in diagnozing a problem that I have with my 42" LG plasma tv (RU-42PZ61).
The initial problem started with two vertical red bars ~2" on each side that would occasionally go away and then return.
By poking around I found to be a possible cold solder joint on the control board (6871QCH038A). By wedging a piece of wood behind the board it would work ok for quite a while. Until one day the image detriorited completly. I believe that I heard a pop one day. I ordered a replacement for this board w/ a different part # (6871QCH060Q) that they said replaces the old one ($240 outch..).
The board replacement did not fix it completly; now it has verticall lines of all colors.
(When I switch to an input that has no signal, the screen reduces to a narrow vertical strip of about 6 or 8"). So I believe that another board was also damaged. (sound is ok)
How can I determine what board is at fault?
On the tuner board (6870VS1984E) there is an led that flashes near the (eeprom?) long IC on a socket. I don't have the service manual for this set.
I will be very thankful to any help that you could provide me with.
Best regards,
Luis
  • 3 more comments
  • Ruka Mar 28, 2008
    i have same problem with my 42" zenith ,
  • bunkers Jul 14, 2008
    Luis, I would love to hear how your problem turned out. I have the same problem with my LG DU42PX12XC 42" plasma purchased in 9/2005. It had a red dot problem that was fixed after the second repair attempt.
    Then more recently, developed a blue bar on the right, then both a blue and red horizontal bar on the red side ... then finally it shuttered and now doesn't display hardly at all. It will after resting, but only for a few minutes before crapping out. Sound work fine, picture fine when it wants to ... but the bars remain and its ability to stay up isn't there anymore. I'm wondering if the 6871QCH060Q part will work on mine. Did you have to replace anything else? Thanks, Scott
  • Anonymous Dec 07, 2008
    Did you ever find a solution?
  • Anonymous May 03, 2009
    TV was turned on and off at wall 3 times and then the multicoloured vertical bars come on. Changing input gives the same 8" RHS side bars, the sound seems OK. After about three or four minutes, the tv turns off. I think it is screwed!. The LG man on the phone said it is either the Picture board needing replacing or the screen is wrecked.
  • macosirb May 18, 2009
    I have the same problem on
    LG RU-42PX11, multiple coulour vertcal line, please can you let me know what I can do. Thanks
6871QCH038A......I replaced this board with one bought at Parts Store.com for 112.00, number 6871QCH038C. Set now works like new with no problems. If this is such a wide spread problems with these sets, LG should have done something to help....
Posted on Oct 08, 2009
Never buy LG products again !
Posted on Sep 06, 2008
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Took lg plasma tv off wall when i put it back there is a fine vertical line which changes colour
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP IN SOLVING THE PROBLEM.....
Aug 09, 2011 | LG 42PC3RA 42 in. HD-Ready Plasma TV
My samsung tv will only show blue vertical lines. It also shows multicolored lines when i hook up anything 2 it. What would cause this> ?
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken, Good luck in solving the problem.....
May 21, 2011 | LG 42LC2D 42 in. LCD HDTV
LG RU-42PX10C Plasma TV picture had colored lines & went black...
This will be your Y SUSTAIN board on the left hand side when you take the back off.
Plenty available on ebay, Very easy fix
Mar 05, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
HEllo I purchased the 42 plasma and was wondering
Go to this site and get the correct manual
http://www.lge.com/products/sidemenu/list/plasma%20tv_PRD|MANU_manu.jhtml
Note you have to be able to get an HD signal for the TV to display it. If you are on satellite TV, then a new receiver is needed.
Oct 20, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Vertical lines on screen of my 42" plasma
Capacitors on Y-Axis board beginning to fail.
Soon the bars will be permanent - get the tv fixed before they are burned into the screen.
Repair is under $200USD (mostly labor)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 17, 2009 | LG 42PC3D 42 in. Plasma Television
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Vertical bar on Daewoo Plasma screen
try this, can't hurt!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
st
Sep 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG MZ 42PZ44 vertical bar
Do some actual reseach and buy a good tv next time instead of a rubbish brand, after all you get what you pay for....
Nov 27, 2007 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
LG 42PX5D 42 in. Plasma HDTV Logo
1,196 people viewed this question
Computer Repairing
Computer Repairing
