Question about Bose Lifestyle 28 System
How do you pry apart a Bose RC-9 Remote control without breaking it, to give it an internal cleaning.
There are 3 tabs on each side, and 1 on each end. Pry with a thin flat head screwdriver, but be gentle as you can break these easily. The first tabs are 2 and 5/8 inches from the top end of the remote, with the others 2 inches away from this. The ones on the ends are dead center.
Posted on Nov 09, 2010
How to check my bose rc-9 remote whether its working or not?
Put batteries in it and point it at the electronics unit and press some buttons
Dec 27, 2014 | Bose New Original RC9 Remote Control
Why does my bose RC-9 remote works only at close range?
1. The antenna inside (It looks like a coil of thick copper wire) gets broken or the solder breaks away.
2. The data cable has been coiled up (to make it neat and tidy). The data cable is the actual antenna to pick up the remote control signal.
Solutions :
1. The remote control can be repaired.
2. If the data cable is all coiled up, spread it out loose and this will make the remote control work much better.
Hope this helps :)
May 27, 2014 | Bose Televison & Video
Bose remote RC-25 won't work anymore
Check the remote control for its infrared emission. Check it with fresh batteries. Check it battery contacts, inside its battery compartment for any rust or dust accumulated, which prevents the electrical contacts. If all are found OK, you remote control need cleaning. To clean it, you have to open it. If you wish to know more details about how to clean and check a remote control, check this link.
Feb 17, 2013 | Bose RC-25A Remote Control for Lifestyle...
I spilled coffee on the remote. Now it won't work
Open the remote control and clean it. Never insert batteries in this wet condition. It will make thing worse. If you wish to know more about how to clean a remote control, check this link.
Feb 08, 2013 | Yamaha RAV-250 Remote Control
Rc-9 remote only works if within 2 feet of bose lifestyle 12
Replace its infrared emission LED. It is weak, and so the signal out from the remote control too.
Nov 18, 2012 | Bose RC-18S Remote Control
My lifestyle remote all of sudden will only work up close. I unwraped all the wires that I had tied up, always had them tied and changed batteries 2 times and did not resolved the problem. The system is...
I also have this probelem. Anyone have a solution? William, what did you end up doing? Was it a receiving problem (from the media center), or a delivering problem (the remote)? Any suggestions would be appreciated.
Thanks,
May 08, 2011 | Bose RC-48S Remote
My Bose remote control RC28TI-27 (for a Bose Lifestyle 48 system) has a heavy rattle in the top portion inside of it. I want to disassemble it and see if it is an easy fix. How do I get it to split apart...
Did you find a solution? I unscrewed the screw under the battery compartment lid near the rear end of the remote. The rattle is a broken radio frequency antenna. A replacement for this ancient remote is $89 plus shipping and handling. Supposedly the Bose systems can also be programmed with some universal remotes without rf antennae.
Sep 25, 2010 | Bose RC-18S Remote Control
I need a replacement remote control - Bose RC9
I have same problem with RC-9 working intermittently with some light banging. Thanks for the tip above. I tried opening the remote but the case wont open. Is there an easy way? Dont want to break the case while opening. Thanks.
Apr 07, 2009 | Televison & Video
Doesn't work
Inside the remote is a ferrite antenna wrapped with a solid copper wire. Over time this large wire solder point cracks. I've had one that rattled. Carefully pry apart the remote and resolder.
Dec 12, 2007 | Bose RC-18S Remote Control
RC 392M remote doesn't work
They usually just snap together, but whatever's been spilled in it may be binding it like glue. Try flexing it by twisting and bending to break the "beverage goo glue"
Aug 30, 2007 | Onkyo TX-DS575 Receiver
Bose Lifestyle 28 System Logo
2,549 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
