Question about Linksys Wireless-G Broadband Router
How to I change my password for Linksys Wireless G? I know the current password or security key but it's very long and my iPhone needs to reconnect from time to time and I hate having to type in the 25 or 27 key code every time.
  • 550 Answers
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Posted on May 01, 2010
  • 355 Answers
It sounds like your router is set up fpr WEP which does require a 27 digit key to connect. you should follow the directions HERE to configure your router to use WPA instead, it requires a shorter key and has stronger encryption. the first section is how you have it configured already scroll down to the section titled "Setting-Up the Wireless Router to Use WPA" and that should be a shorter key....
Posted on Apr 30, 2010
It says my security is not on my wireless is wide open
Hi and welcome to FixYa.
I am going to walk you through changing your password on your router.
On a computer connected to the linksys now.
type the numbers below into your browser and hit enter
192.168.1.1
On the page that comes up, it will ask for a username and password.
type in admin for the password, leave the username blank
You are inside the router..
Click on wireless, then right under it click on wireless security.
Where it says, PSK / Passphrase / Or Network key .. There is a text box to the right
In that text box is your password.. If it looks like ************** or blank if you haven't set one.
You will have to type in a new password, and click apply / save settings.
Then.. The router will restart..
You have now found out, or reset your wireless password.
***Note*** If you changed the password.. The current computer will also have to reconnect to the network, and enter the new password.
If you have any questions or get stuck, message me.
KittyTech
Sep 11, 2011 | Linksys Wireless-G WRT54G Router
Tip
How to check the wireless settings on your Linksys router
Do you need to know the wireless settings configured in your Linksys wireless router? This tip will you do this, I will show you how this can be done.
First, why do we need to know the wireless setting of your router?
Here are a few reasons why we need to know all of these:
  • We need to know the wireless settings if we wan to add a computer to the wireless network that you already have.
  • If we want to add a wireless devices like, wireless gaming adapters for your gaming system like Xbox.
  • You will also need to know the wireless settings of your network if you want your mobiles phones and other gadgets (iPhone, iPod touch, iPad,etc.) to get online through your wireless network.
What are the things we need to verify off of your router setup page? Here they are:
  • SSID - Wireless Network Name
  • Channel
  • Type of Security
  • Security code or password if there is one enabled.
Here are the steps on how this can be done:
  1. In your computer that is connected to the router, open your browser and type or copy and paste this link to the address bar http://192.168.1.1then hit return.
  2. A login box will pop-up asking for a user name and password. Just leave the user name field blank and type admin in the password field.
    Note:
    admin is the default password, if you can't login using the default password, you might have likely changed it during the initial configuration of your router.
  3. Once you are in the router Setup page, click on the tab at the top that says Wireless. In this page, you can get the following information.
    • Wireless Network Mode - This setting will allow you to choose if you want different types of wireless connection can be accepted by the router, you can choose B, G or Mixed. I recommend you leave it to Mixed.
    • Wireless Network Name / SSID - This is the field where you can put in the name you want for your network.The name you will set here will the name that your router will be broadcasting. By default your router uses the name "linksys". Imagine if the rest of your neighbors has the same brand of router.
    • Wireless Channel - This is the channel or frequency your router is operating on. This can be changed if you are having intermittent issues with your wireless network.
    • Wireless SSID Broadcast - This is one setting that is worth checking. If this is disabled, your router is still operating but the name of your network will be hidden. It's recommended to leave it enabled.
  4. Then click on the sub-tab under the Wireless tab that says Wireless Security. In this page, you will be able to verify the following information about your wireless network security.
    • Security Mode - By default this is set to Disabled. And these are the common security type used or enabled in a small office, home office netowrk.
    • WEP (Wired Equivalent Privacy) - If this is the type of security that is enabled in your router, you need to look for the "Default Transmit Key" or "Default Tx Key" this will tell you what key you need to use from the list of keys available. See image below for reference.
    • WPA Personal (WI-FI Protected Access) - if this the security that you will see, you need to take note of the "WPA Shared Key" this is the password for your wireless netowrk. You can change this any time, and it should be a minimum of 8 characters. Note: If you change your password for the wireless, you wireless computer and other wireless devices that were able to connect fine prior to changing the password, may need to be reconfigured or reconnect and use the new password.
    I hope that this will help you readers out there. Thank you for dropping by.
on Jun 20, 2010 | Computers & Internet
I need to change the security key for Linksys router. Using Windows Vista unfortunately.
Try opening your web browser then see if you're able to access http://192.168.1.1 and if your then prompted for a username and password try entering 'admin' for the username and password (unless you changed this at one point). Once you've logged in you should see a 'Wireless' tab or option then you should see a sub-tab for wireless security that you can then use to change the key or view the current key.
Feb 27, 2011 | Linksys WRT300N Wireless Router
How to find your wep key?
Hi and welcome to FixYa!
Usually if you go and look for it, it is going to be blackened out with stars or Astrix. We can reset your router to take off the encryption though and make a new one.
Click the link below
192.168.1.1
Let me know how this worked for you!
KittyTech
Feb 02, 2011 | Linksys Wireless-G WRT54G Router
How can i change my security key
Hi and welcome to FixYa! We are going to change your password for you, but the way you worded your question, i am assuming you already have one on there.
192.168.1.1
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
Jan 08, 2011 | Linksys Wireless-G WRT54G Router
Need to locate security key or passphrase
I can show you how to get into your router, but more often than not, your pass phrase or password is going to be starred or Astrix out. I can show you how to reset it without knowing or remembering it.
192.168.1.1
KittyTech
Nov 25, 2010 | Linksys Wireless-G WRT54G Router
Can't remember my wep key for my linksys router
That will not be a problem. Let's set you a new one.
192.168.1.1
KittyTech
Nov 24, 2010 | Linksys Wireless-G WRT54G Router
How can I change the password on my Linksys router (WRT54G)?
192.168.1.1
KittyTech
Nov 22, 2010 | Linksys Wireless-G WRT54G Router
Need to reset my password.
To reset your password;
192.168.1.1
KittyTech
Aug 29, 2010 | Linksys Wireless-G WRT54G Router
Change password, linksys router, wrt54gs
are you referring to the wireless password like WEP or WPA key? if yes,you need to connect your laptop first to your router with a cable,go to 192.168.1.1, then enter,username should be blank ,password is admin, theres a setting there for wireless security
Oct 10, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
129 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
