Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
Problems with internal speakers of the Samsung LN32A450 TV
Apparently my speakers are broken. No problems with high frequencies, but low frequencies produce an annoying sound characteristic of broken speakers. Can I buy replacement speakers and install it myself. Or do you recommend install external speakers instead?
Thanks
Gilberto
  • Samsung Master
  • 10,291 Answers
Posted on Sep 12, 2016
Problems with internal speakers of the Samsung tv Can I buy replacement speakers and install it myself.
Posted on Jul 24, 2011
Subwoofer makes noise like an untuned TV regardless of volume knob
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
Jan 18, 2014 | Cambridge Audio Minx X300 - Powered...
I put a sub in my 2002 Altima but when I turn it up the bass cracks on the door speakers??? What do I do to get all the bass on the sub
Hi Ethan,
What you're looking for is called a "crossover". A crossover is an electronic filter for an audio or speaker circuit. In an audio circuit, a crossover is used to prevent or pass certain frequencies or a range of frequencies from passing through it. Since your sub will reproduce the bass or low frequencies, you don't want other speakers to reproduce them. A band pass filter on your door speakers will do this for you. A band pass filter passes only a range or "band" of frequencies and blocks those that are above and below the range or band of frequencies selected. Installing a band pass filter will prevent the very high & very low frequencies from getting to the door /dash speakers. Likewise, you should consider connecting a low pass filter to your subs, too. The low pass filters work a little differently from of the way band pass filters work - they only allow low frequencies to get to the sub - blocking all the other higher frequencies (your other speakers are better suited to reproduce those). Lastly, you would install a high pass filters on tweeters. Tweeters are designed to reproduce only the high frequencies - sending mid and low frequencies to them is wasting power and can cause damage to them.
You purchase the filters for specific crossover points (the block / unblocked point) as determined by the individual speakers. If a sub has a frequency response of 20Hz - 100Hz, a low pass filter of 100Hz would be ideal. Remaining filters would need to begin at 100Hz - assuming the mid-range speakers have a frequency response beginning at 100Hz. A band pass filter of 100Hz - 3KHz would fit the bill nicely if the mid-range speakers go up to 3Khz Match the high end of the band pass to the high end of the frequency response of the mid-range speakers. Next, a high pass filter at 3KHz would allow only the high frequencies to your tweeters. Basically, you want to have the entire audible range 20Hz - 20KHz covered by the speakers and have the crossover points that match the frequency response ranges of the speakers.
I hope this helps & good luck!
Apr 12, 2012 | Pioneer Car Audio & Video
Tv went dead
You need to inspect the power supply first, look for blown main AC fuse and any bad caps with domed tops, see example of failed Samsung TV here:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/
Also read my guides:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 23, 2011 | Samsung LN32A450 LCD Monitor
Please help! I was playing my keyboard and i decided to have the volume a little higher and suddenly i heard and unbalanced output sound from the two of my monitors. I discovered that one of them only...
This is a BI-AMP powered speakers setup, the power amp for the woofer is still working but either the high frequency power amp for the tweeter is blown or the tweeter speaker is blown, you will need to use an Ohm meter to check the tweeter and the fuse in the high frequency amp.
Feb 11, 2011 | IKEY-AUDIO M-606 POWERED STUDIO MONITOR
Our power went out for a brief moment and now the Samsung LN32A450 LCD TV we have isn't working and there is only a blinking red light on the bottom. Any suggestions?
Try unplugging and plugging it back in. Was there lightning, and was it attached to a surge protector?
Try pressing the power button repeatedly or even slapping the back of the tv (try googling this).
Oct 20, 2010 | Samsung LN32A450 LCD Monitor
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here: http://www.jbl.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=PSW-D110
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
My Yamaha SW118 keeps cutting out (volume reduces to v low level) even when driven by 500W amp. Doesn't seem to be the amp but not sure if the speaker has it's own internal protection. Can anyone advise?
Poly Switch
All full-range loudspeakers are fitted with a self-resetting
poly switch that protects the high-frequency driver from
damage caused by excessive power.
If a loudspeaker cabinet loses high-frequency output, immediately
remove power from the unit and wait for two to three
minutes. They should allow the poly switch to reset. Reapply
power and check the performance of the high-frequency
driver before continuing with the power reduced to a
level that does not cause the poly switch to interrupt the signal.
On the SW115V/SW118V/SW218V sub woofer, the Poly
Switch protects the woofer and a similar routine should be
followed if its output is lost.
Aug 29, 2010 | Yamaha SW118-IV 18" Subwoofer Speaker
My Samsubg PN42 was built in Sept 08 so no more warranty. Speakers rattles with low frquencies. OK when listening through receiver. Does anyone knows aproximate cost of replacing speakers in a flat plasma...
The problem is inside of the tv. Your speakers are probably fine. The problem in most sets I have found is that the internal parts/Brackets are vibrating particularly at the lower frequencies. You must insert non conducting foam and duct tape to immobilize any moving parts. With the back of the set off, Tap the chassis with your finger and you will hear where the vibrations are coming from. Repeat taping and inserting the foam until the vibrations stop or are minimized to acceptable levels. You can also adjust the custom audio with the equalizer to cut the base frequencies. This is a common problem. In some cases I have found Bad speakers and need to be replaced and is really simple to do with the back panel removed. Once you see the speakers you will how simple it is to replaced the speakers.
Apr 15, 2010 | Samsung Televison & Video
My Samsung TV(LN32A450) does not turn on
If the standby light flickers off every 5 seconds or so, see the solution here
Feb 08, 2010 | Samsung LN32A450 LCD Monitor
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
424 people viewed this question
Jerry Greenberg
Jerry Greenberg
