Question about Taylor Biggest Loser 7303 Electronic Scale by with Bonus Biggest Loser 2
Scale doesn't work
I put in a new battery and it still doesn't work
My scale (thinner)MS 7400 stop working?
Most likely the batteries need to be replaced. If you put in new batteries and it still doesn't work, it may be time for a new scale.
Mar 02, 2015 | Health & Beauty
Am trying to add clarification to an earlier question. The scale I am asking about is a wall mount kitchen scale: the make is Salter, the model 1601. It worked fine for several years until I changed t
Is it possible you put the batteries in the wrong way? Sometimes a device will still have power in that situation, even though it won't work as expected. Try a new set of batteries, but clean the contacts in the battery compartment first, and double-check the battery orientation.
Dec 20, 2014 | Salter 2001 electronic kitchen scale
Undefined
Most likely the old battery was so low the scale was reading low.
Oct 13, 2014 | Health & Beauty
I have the thin kitchen scale. After changing the battery, the display keeps flashing. How do I get the scale to work again?
I had the same problem, I am not sure why but it seems like the circuits misfire when you change the batteries (perhaps a capacitor holding a charge or a diode stuck).
I got mine working again when I put the batteries in backwards (trying to discharge any capacitor that might be holding a small charge still) and then hit the power button with the batteries in backwards; then put the batteries in properly and hit power again.
please note that I am NOT an electronics professional and I have no idea if this is harmful to the scale or not, but it worked for me and the Polder scale is working as designed once I did the procedure. Hope it helps.
Jun 24, 2014 | Polder Slimmer Digital Scale
How do I reset my Weight Watchers Scale WW67T? It doesn't matter who gets on, we all weigh 150.1 pounds. How can I reset this? I put in a new battery also. Thanks
Wexem,,,, thank you. Your instructions worked like a charm. Sad that the manual doesn't mention or contain reset instructions.
Feb 04, 2012 | Health & Beauty
I bought a new scale, but for some reason it doesn't work. I checked the battery and tried the scale on bathroom floor. It still doesn't work. What would you advice?
Hi
Thank You for rejecting the session and down rating my assistance even though I tried to help you. That was an honest answer which off course you rejected...please post back for further assistance.
Daniel
Sep 15, 2011 | Conair Weight Watchers WW-87 Body Fat...
I have a Taylor 9856 scale. The batt message came on so I changed the battery. Now it doesn't work.
"After replacing the 9-volt battery, the scale wouldn't turn on. I tried new Duracell and a Kroger brand batteries. I eventually discovered that the stock battery (Tianqiu brand) was shaped slightly differently from the new batteries. The minus contacts were not quite touching. Luckily, I just had to bend out the connector on the scale so that it touched the battery. Now it works again."
Aug 06, 2011 | Health & Beauty
The Homedics SC 380 scale said low battery. After the battery (3V DL 2032) was replaced nothing works (does not turn on). Why would this happen? Is there a reset button or a button that turns it back on?
The same happened with me, but here is what I did and it worked. I took the new battery out and set the setting on the bottom of the scale to Stone, put the battery back in. Now when I put the battery back in I made sure the plus on the battery was the last part to go in, it faced the part inside the casing that needs to be pushed back when you take out the battery. Once it was in I put the setting back to LBs and it worked. Don't know how but I was just as frustrated and it worked.
Jan 28, 2010 | Homedics Health & Beauty
Hello my taylor 5589 fat scale doesn´t work anymore. each time i weigh myself it says err2. i changed the batteries and it´s still the same.
Had the same problem with mine and sent it back since it's under warranty. Taylor did not need a receipt and I just received a new scale today, model 5742 although it cost me just about $20 to ship it back and that's UPS ground! The scale retails for $29.99 on amazon.com. Good luck!
Dec 01, 2009 | Health & Beauty
I put the new battery in my Taylor 7004 V1812 and the screen rem
Check and see if you put the battery in right. Make sure the rough part is facing bottom.If this doesn't work your battery may be bad.
Jul 22, 2009 | Taylor & Digital Scale Lithium Scale
Taylor Biggest Loser 7303 Electronic Scale by  with Bonus Biggest Loser 2 Logo
127 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
