Question about Dishwashers
Water does not start
When we start the wash cycle there is no water. All valve are open and the wash cycle was working the other day
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote about that....
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Apr 30, 2010
Spin cycle on washing machine not working
The spin cycle relies on the sensors turning on the sump pump to pump out the water and a solenoid valve to open to allow the water to drain. They are both controlled by a water sensor located in the bottom of the machine. If it does not sense the water it will not let the pump start or the drain valve open. Check it out.
Jan 12, 2013 | Washing Machines
Haier model HLP21E. The wash cycle doesn't seem to do anything but the rinse cycle and spin cycle work well.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Click this link: Inlet valve
Jun 25, 2012 | Haier HLP21E Top Load Washer
Its not working at all i lift it unpluged all nite and still wont working and it was just working two days ago
Nov 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Put wash on, no water have checked water supply all ok ?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. In this case the inlet valve is not working and allowing water to flow . Check the voltage on the inlet valve, if absent then the program controller unit if faulty. If not the inlet valve must be checked
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 21, 2011 | Zanussi Washing Machines
Fisher paykel aquasmart washer will not pump water into itself to start the wash cycle,display is working fine
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. In this case the inlet valve is a suspect if there is voltage when switched on but fails to open.
Sep 02, 2011 | Washing Machines
The washing cycles both (pre-wash and main wash) can't work through to the end. when the water has been filled, the four indicating lights flash together and sounding like tide with rhythm. when...
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect since the cycle when advanced seems to go through well.
Aug 27, 2011 | Dishwashers
My top loading washing machine stops before spin and so water does not drain. outlet hose is not blocked. it just stopped working one day
Now if the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
If the motor does not start even when the water level is reached and inlet valve cut off, then check the output to the motor, if absent the controller is faulty if not check on the motor, motor capacitor, belt.
Aug 23, 2011 | LG Washing Machines
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
