Question about NAD C320 2-Channel Amplifier
Amplifier overheating and swtching of
Hi I have expericed my amp overheat and switch off on two occasions when connecting it to a mixer. It plays ok for a couple of hours but then overheats.
It is connected to the same set of speakers (Yamaha) I have at home and I haven't experienced over heating at any time then.
Apologies for not putting any more specifics on the type and size of speakers. If you require this information please let me know and I will get the details.
Cheers
Zoe
  • zsbeat Apr 06, 2008
    Thank you for your reply, apologies for the delay i have been away.
    I also sent a separate email if you are wondering who that was.
    My NAD amp is C 320BEE and my speakers are
    Yamaha NS 55.
    Cheers
    Zoe
    Novelist:
  • 236 Answers
You need to provide me the specs of your amp, your speakers. Impedance important. You are experiencing overload, overheating caused by overload. You have a wider frequency range using a mixer and that affects the output stage of your amp and can cause to fail.
I am from Yamaha service before and they have speakers that has 4-6Ohms impedance only. And you have to know your amp if capable of handling such low impedance. you may not have problem with the power but it should be impedance.
[email protected]
Posted on Mar 25, 2008
  • Anonymous Apr 06, 2008
    Please try to find out the specifications of your NAD, im not familiar with the model. if you can look at the back panel to find the output power ratings like watt per channels (RMS) and the impedance of speakers (you will see that somewhewre in the speaker terminals). I weanted to know first if your matching is possible. because definitely you have an overload but maybe there is a way to solve that by switches at the back panel. See if you have a speaker impedance selector. NS55 is medium power speaker system. But it may be possible that oyu have overdriven the speakers one time and that the voice coils must have gone shorted a little and impedance became lower then. that will cause your amp to trip.
    sorry...
    have you tried using the amp without the EQ? please try it and see if it will still does the same turning off. I have checked the specs of your amp and speakers and your speakers has got a lot of power to handle. it is a mis match with your amp but it wont cause any problem though because your speakers gets more power handling capacity than the amp. anyway... just try bybassing the EQ and see if it will still trip. if it doesn't then you must be overdriving your amp not your speakers. because the power output of your NAD can handle up to 110W depending on your loads. if you power uo too much then it will cause your nad to trip. the impedance of your yamaha speakers is 6ohms rated at 250W... thats a lot of power to handle and 100 % more than what your amo can give. But the thing is are you sure at no time you have tried to poiwer up the amp too load that the sound of your speakers are already distorted? what type of music do you frequently play? bottom line is load resistance...you are overloading. or maybe another solution is give your amp a better cooling system, a fan on top. prolonged use of your amp at high power will require more ventilation. if you are experiencing chutting of at high volumes only then maybe you can use a blower fan on the top grill. it may not look good in your furniture but it wil help. if you are setting up your audio system, i suggest that you dont put anything on top of your amp to give better ventilation. normall we tend to place the amp at the bottom, that is not good for we choke the vents for the amp and it will cause trouble. I hope your speakers did not get damaged. if you don't hear an abnormal sound performance ony oru speakers specially your woofers, then it could be your mid range or the tweeters. It could even be the crossover networks. but its very hard to tell now which is which. we isolate first one by one. ill guide you.
    1st bypass the EQ and see if it will work normal. if it does then put it back again. try to use a fan on top of the amp and use it at hig volmues for a while, giving it more ventilation. if it does not trip then it is only a case of overheating. if it doesn't trip often and occassional only, there should be nothing wrong with both amp and speakers. you just need to ventiallte it well. try it first then let me know..
    God bless
    reden
SOURCE:
I have a studiomaster vision 8 powered mixer the
Probably you have a missing voltage at power supply which should be +15V/-15V connected to a number of opamps in the mixer section of the circuit, NOT in the power amp section, let me know to help troubleshoot your issue.
Nov 01, 2013 | Audio Players & Recorders
I have a behringer EP1500 amp, connected to a behringer mixer VMX100. i am getting a popping sound, the sound is random, it happens at various times, so i cannot say it always happens after i have...
hi,
check the power outlet socket to which the amp and mixer is connected. if there is any loose contact in that power socket, this problem can occur. try to use a good surge protector with emi filter for connecting the amp and mixer.
ok
Dec 29, 2010 | Behringer Audio Players & Recorders
My Technic 1200's are only playing out of one speaker at a time.
Clearly there IS a setup issue. Take serrato out of the loop for the moment and the mixer. Plug each deck (one at a time) into a hifi with a MM Phono input. Are you getting stereo? If yes, you know the decks are ok. Now reset the mixer completey. All eqs and pans including volumes to 12 o clock position and volumes to 0.
Make sure you connect deck one to a red and white of one phono input channel. Do not use 1 channel from phono and 1 from line. Use both left and right of the phono chanels.
Ok, now hook up the mixer to the amp. Keep the x-fader on channel 1 and concentrate getting a good stereo signal from this one chanel. Now do the same for the other cahnnel.
This should hae helped you to get up an running, if not narrow down the problem.
Apr 18, 2010 | Technics SL-1200 Turntable
I have static in my microphone on my idj2
My idj2 gets the same problem after 3 hours. For two hours it sounds good, I am using a shure sm58 radio mic. The only way i can get rid of the static sound is re booting the system then its ok.
Mar 05, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
Connecting a behringer djx700 mixer to a panasonic amp
The problem is most likely between the turntable and mixer. You need to be sure that the turntable is connected to a phono input. I'm not sure if your mixer has one. If not, you need to have a phono pre-amp between the turntable and the line input on the mixer.
Check that first and get back to us if you still have problems/questions.
Dan
Aug 21, 2008 | Audio Players & Recorders
Cant't get it to work
Are you running your keyboard etc through an amp or mixer? You need to connect the pre-amp outputs / tape outputs of that amp or mixer to the analogue inputs of the cdr.
Jan 29, 2008 | Philips CDR785 3-Disc CD Recorder
Technics SU-V460 Amp Problems
Hi There, you need to eliminate all the connection and surplus items around the SUV-460 amplifier to determine if its the amp or not..
That is disconnect every thing then connect just the speakers and an input to the amp like a CD player or radio input. Then see if the amplifier plays OK thru the speakers on both channels and the balance control works fine....If it doesnt then the fault is inside the SUV-460 but if it all works fine than start reconnecting theemixer panel carefully and recheck all your cables and connections. Its a process of elimination to determine if its a "Box" fault or a cable fault...
Cheers From YUBEUT
Nov 14, 2007 | Technics SUV500 2-Channel Amplifier
New to PA systems......
What brands are we talking about my friend?
Oct 09, 2007 | Audio Players & Recorders
NAD C320 2-Channel Amplifier Logo
424 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
cheekygr1n
Level 1 Expert
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
