Question about Invicta Corduba Skeleton Techno Strap Black Band/Black Dial 7135 Watch for Men
Does my 2010 invicta corduba have pins or screws in the braclet? how do I remove them? They look like screws but juts spin around both way when i turn them.
  • 299 Answers
Sometimes the split ends of pins look like screws. If the slot is extremely thin its a pin A screw slot will be a bit wider. I pin removal toll inserted into the smaller end should do the trick.
Posted on Apr 30, 2010
I just got a Invicta Corduba watch and I need to set the time. How do I do that? The number on the back is #6675. Thanks
this watch has a screw down crown. lift up the protector bar or start to unscrew down until it pops out, then turn slowly and pul gently all way out. set the time . tere is 2 positions there. full out time and inbetwwen them is the date and day settings.when there turn up or down until date chages, if it has day and date , up is day down is date.you have to turn few times for it to move..set the date ,set day before and go around . the 12 see number change to might date, set the correct time am or pm. push the crown in and screw in up til hand tight.
Jun 17, 2011 | Invicta Watches
Invicta corduba #4898. Crown will not pull out to adjust time and date. Large cap removed, smaller croen head will not come out. Is there a trick to it? Thanks, Steven
Divers watches usually have to have extra strong seals to prevent water getting in. This often achieved by screwing the crown wheel (to the right?) after it has been pushed home.
To pull the crown out, first rotate it anticlockwise about 1/4 of a turn and then pull.
Jun 16, 2011 | Invicta Corduba Ibiza Diver 4898 Watch for...
How do i get links out of invicta Corduba Swiss Chrono?? do they screw out??
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes
Apr 03, 2011 | Invicta Watches
Does my watch have a battery or do i have to wind it? I tried winding it but it still isnt working I just want to be sure before i bring it to a repair shop. I thank you in advance. Thomas
mcdevito75 here, If you try to wind your watch listen for the distinctive click, click as you wind, if you haer this click, click then it"s a a windup, if the stem just turns without the distinctive sound click, click. then it"s a battery watch, also look for any word on the watch that says Quartz. ONE more thing, you may have a screw down cover on the winding stem, un screw the cover on the stem to get to (the crown, winding stem itself) Most likely you have to un-screw this cover on the stem to get to the actuall stem itself, Invicta makes watches like this to add waterproofing to the watch.
Nov 19, 2010 | Invicta Corduba Luminous Multifunction...
The stem cover will not open, not sure why, and also not sure which end to exert unusal pressure, as nothing works now short of getting out a screwdriver and trying to pry it open. also, are the upper and...
mcdevito75 here, the stem may have a screw down cover if it"s been screwed down to tight you may not be getting a good enough grip to loosen it, Look for a small watch repair shop for this problem. Donot use ant tools yourself to loosen this screw down cover.
Jul 07, 2010 | Invicta Corduba Skeleton Techno Strap...
I DO NOT KNOW OR EVEN BEGIN TO FIGURE OUT HOW TO
Invicta watches either have screws or push pins. The one I sized yesterday had screws; it was tricky because I had to hold a flat head screwdriver on one side of the pin and then another screwdriver on the either side to unscrew it (this kept it from just spinning without loosening). If it is a push pin (you will know by looking because either a screwdriver will fit in the head or not) then you will need to get a thin steel rod about the width of a paperclip, a hammer, and a block that you can support the watch on. Push pins are pressure set and you just have to tap them out with a hammer by hitting the pin pusher/ steel rod into the pin hole to knock it out. Knock out the pins to the links you want to remove and then use a pin to resecure your watch band together.
Oct 21, 2009 | Invicta 8937 Wrist Watch
How to remove watchband links from an Invicta watch
Oct 20, 2009 | Lucien Piccard 26024 Wrist Watch
Invicta Corduba Skeleton Techno Strap Black Band/Black Dial  7135 Watch for Men Logo
334 people viewed this question
Top Invicta Watches Experts
Jimmy Accardi
Geoff
Are you an Invicta Watch Expert? Answer questions, earn points and help others
