Question about Epson Stylus Photo R2400 InkJet Printer
Yellow ink blinking
I am printing for a friend as her printer hasn't been used for a while and yellow ink is blinking. What to do?
    Problem Solver:
  • 8 Answers
In my experience a blinking light over the cartridge means the cartridge is low. When the light is solid it means the cart is empty and the printer will not print until it is replaced. With the blinking light, have a new cart on standby but keep printing until the printers makes you stop.
Posted on May 07, 2010
  • 96 Answers
Please clean the printhead using the software installed in your PC . Try printing now.
Posted on Apr 30, 2010
Epson Workforce 840 prints yellow as purple, then panel blinks continuously saying print error has occurred
There isn't much to go wrong in a printer. If you've had the cartridge for a couple of months, I would venture a guess that you ran out of "Yellow" ink. One other possibility if that the wrong driver is installed for your printer (if this is a recent purchase) and that the driver being used is pulling Magenta instead of Yellow.
Nov 04, 2013 | Epson WorkForce 600 All-In-One InkJet...
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
HP Officejet Pro K8600 won't print in color, just in black
Ink levels are an estimate. They are approximated according to how much color might have been used. You may be out of all the color inks, they may be dried out or clogged. There should be a head cleaning operation for the printer, but it uses ink too.
Feb 07, 2018 | HP OfficeJet Pro K8600 Printer
Yellow ink will not print
On the Brother MFC series printers it uses remote ink trays as you will know, instead of having print heads directly on the ink cartridge. Whilst this approach makes it cheaper to produce the ink, and easier to change the cartridge, it can make it difficult to clear clogs.
There are several things you can do which may help, but B. and C. are at your own risk. All steps assume you have a new yellow ink cartridge.
A. In paint or another program, create a full page yellow image and keep printing it out. See if it gets any better after each print. If it does, continue until it seems to be working fine.
B. If you can manage to get to the print head, you can get a cue tip, dip it in rubbing alcohol and gently clean the print head. Leave 20 minutes to dry, and then do step A. again.
C. (AS A VERY LAST RESORT AT YOUR OWN RISK. THIS IS GOING TO RUIN YOUR YELLOW INK CARTRIDGE SO USE AN OLD YELLOW ONE IF YOU CAN) If steps A. and B. fail, you can put a "little" rubbing alcohol in the Yellow Ink Cartridge, and keep trying step A. If Yellow starts printing again, swap to a yellow cartridge that does not have rubbing alcohol in it. You are now going to have to cycle through many pages to clear the rubbing alcohol from the ink lines.
Note that if you keep cleaning the cartridges, it is going to use a lot of ink, and may actually hinder solving your yellow ink problem.
Good uck
Apr 24, 2010 | Brother MFC 240C All-In-One InkJet Printer
Hp Besiness inkjet 1100 fault codes cayan maginta ink and paper lights come on dead
HP Business Inkjet 1100 stops everytime after the first line stars to print. The power is one, the ink drop light is lit, the "yellow" indicator light also on, and the paper light all on. None of them blinking. We replaced the yellow cartridge with a brand new HP 11 yellow cartridge. Turned the printer off and on to reset. Printer comes on everything looks good till you try to print anything, even a on line word doc? Then it happens again, so we replaced the yellow again...same thing. We ever cleaned print heads, Any assistance would be welcomed?
Jan 12, 2010 | HP Business Inkjet 1100dtn Printer
The yellow spot is blinking and the black dot is
the solid light means toner is low. Blinking usually means either the cartridge is out of toner or the cartridge is having a technical problem. If you pull the yellow toner cartridge and put it back in with no change in result, you will need to replace the yellow toner cartidge
Nov 19, 2009 | HP LaserJet 1500L Printer
Out of yellow ink but only want to print in B&W
please you use the coloue paper print other black and white paper print ?
but you use the only yellow paper print ?
you refling the colour cartridge and setting page in colour prints
and use printer.
Sep 27, 2009 | Brother MFC-260C All-In-One InkJet Printer
The yellow light blinks and it won't print
I also started having problems with my HP 870Cse when I began using refilled cartridges and had ink leakage (cartridge contacts corrupted). Check for this problem. If so, remove cartridges and gently clean the spillage. Then try using HP brand cartridges and see if this doesn't remedy the problem.
Jan 21, 2009 | HP Deskjet 870cse Printer
Will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Oct 27, 2007 | HP DeskJet 960c InkJet Printer
Epson Stylus Photo R2400 InkJet Printer Logo
217 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
