Question about Acer AL1716 17" LCD Monitor
Monitor is distorted
Works fine from time to time. when it doesnt, there are weird distortions. brightness pixelation clarity and what not, i can see images but just an idea of them not an actual clear picture or video
  • 11,361 Answers
You may want to open it up and inspect the caps (bad caps with bulging tops) as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1716/
Bad DC filter caps can cause alot of strange symptoms.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 30, 2010
There is bright green vertical line occurred on middle of the screen
I am afraid your computer's screen has a defect. You should apply to nearest service. If your computer is still in the guarentee period thats fine. There may be exists different guarantee conditions for LCD screens, (death pixel guarantee) and some brands give this against even 1 death pixel. You have lots of death or distorted pixels (a line). Do not lost time and apply to your vendor.
Regards.
Aug 24, 2010 | HP w1907 LCD Monitor
Signal outof range
  • Make sure the pins on the video cable are not bent or damaged.
  • Make sure there are no extension cables or switch boxes attached to the monitor.
  • Verify that you have the proper drivers installed for the video card.
  • Verify the problem at all possible resolutions and refresh rates.
  • Make sure the refresh rate does not exceed maximum value for any resolution.
  • Test the monitor on a different computer.
  • Contrast is recommended to be set at a higher range while the brightness should be set at middle range. This helps to increase the text clarity while reducing the bright background.
  • If your monitor is equipped with moire control, adjusting this may improve the clarity of the text. Moire is a wavy distortion pattern caused by interference between the dot pitch of the CRT and the picture signal. The pattern may vary depending on the screen amplitude, contrast, brightness, and other characteristics of the input signal.
  • Monitor's performance may be affected by the Earth's magnetic field. Try rotating the monitor to different directions to improve misconvergence.
  • Most video cards offer a software utility that changes the frequencies and sync polarities for all resolutions. If the setup does not match with the monitor's characteristics, an incorrect signal may be displayed on the screen. Sometimes, the image may also appear blurry.
  • Aug 08, 2010 | Compaq TFT8020 18.1" Flat Panel LCD...
    There are these lines of static, distortions across my screen that only visible in certain situations. For instance, as I am tying this the bottom of the words 'static, distortion' are distorted (looks...
    Go into control panel, properties, advanced, monitor, refresh rate and select display refresh rates that my monitor can display and then choose which one best suites you and your problem.
    Jun 26, 2010 | Gateway FPD2275W LCD Monitor
    Distorted images
    try to change resolution settings.
    right click on your desktop and click properties.. >> go to settings tab and change the resolution and colour quality and see if it works.
    Good Luck!
    Feb 26, 2010 | Dell E228WFP LCD Monitor
    Flatron w2043s 20" there is distortion on all letters and numbers etc, its as if its ran out of ink ,spoils the picture big time
    The distortion mostly is caused by a wrong screen resolution. Choose another (smaller or larger) resolution and once you've found the correct resolution for your display card tne distortion will be gone.
    Aug 03, 2009 | Computers & Internet
    Laptop Screen distorted.
    Your LCD ribbon cable that connects the panel to the motherboard might be damaged. I recommmend calling HP to get it serviced, or go to your local computer repair shop and have look at it. Hope this helps!
    Jul 14, 2009 | Compaq Computers & Internet
    Sony a100 distortion dots - Im getting several
    If these are single pixels on the LCD screen, they are normal. From pg. 8 of the user's guide:
    "The LCD monitor is manufactured using extremely high-precision technology so over 99.99% of the pixels are operational for effective use. However, there may be some tiny black points and/or bright points (white, red, blue or green in color) that constantly appear on the LCD monitor. These points are normal in the manufacturing process and do not affect the images in any way. "
    This may also be helpful.
    "images may trail across the LCD monitor in a cold location. This is not a malfunction. When turning on the camera in a cold location, the LCD monitor may become temporarily dark. "
    May 03, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
    Peavey Bass Amp TKO115s
    Start with a clean setting - zero cut and zero gain on the Eq. Play a song close to the amp, and then move away, playing the same notes. Do you still get the distortion? Change lower the input gain and repeat the test. Lower the output gain and repeat. Are any outboard distortion pedals in the mix, such as overdrive? Eliminate them. Run straight through from your axe to the amp. Check for any distortion settings. Set everything including reverb to zero. When the distortion disappears, this is your base setting.
    Change only ONE parameter at a time. When the distortion comes back, you have found your problem.+
    Dec 03, 2008 | Peavey EQ215FX Home Equalizer
    Images all lines and stripes on monitor and photos
    Put the right batteries in... I had same on my camera...Lines and distortions but sine i use uniross rechargeable 200mah the problem has disappeared. go o www.uniross.com to get them. Saved me buying a new camera...
    Sep 28, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
    Monitor
    Adjust the pixels. Right click on desktop, properties, appearences, advanced and there should be a slide bar to adjust your pixels. Make them larger, ex. 1440X900 instead of 680X400
    Jul 15, 2008 | E-Machines eMachines Monitor E15T4
    Acer AL1716 17" LCD Monitor Logo
    111 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
