Question about HP w1907 LCD Monitor
Hp w1907 has white screen in vga and dvi-changed computers doing same thing-tried another monitor and it works on both computers
  • 105 Answers
The all white screen indicates loss of 5 VDC to the LCD panel. Either the connector is not plugged in good or (more likely) the panel itself had failed. They can develop a short that blows the 5 V fuse on the panel. Replacing the fuse normally does not fix the problem.
Monitor Mike
Posted on Apr 30, 2010
Hp w1907 monitor cord does not fit my hp computer is there any adaptors i can buy
Yes there are many adaptors, go to your local computer store and find the correct one.
Take note as there a number of connection types as shown below:
VGA blue connector.
DVI White connector
HDMI ususally a narrow black connector.
Thanks
damnor01
Mar 21, 2011 | HP w1907 LCD Monitor
No vga input/dvi input monitor going to sleep. irksome! can somebody give the appropriate solution. tns.
When i turn my computer on my monitor keeps saying no vga input and no dvi input then the monitor says going to sleep ..........PLEASE HELP ME!!!
Feb 10, 2011 | HP w1907 LCD Monitor
My hp monitor flashes no dvi imput signal
First, make sure the dvi cable is hooked properly to the computer and that the computer's VGA card's dvi output is set to work in the monitor's advance options.
Has this computer/monitor combinatioin ever worked before? Or did the message appear after successful operation of dvi to the monitor?
Perhaps, try to use a vga cable to the lcd monitor to see if that input works.
Good luck on this repair.
Jan 28, 2011 | HP w1907 LCD Monitor
My monitor will not allow me to even get a menu screen with the computer off. How can I get it reset back to factory settings without accessing the monitors menu? Should I just get a new monitor?
What is wrong with your hp w1907 lcd monitor? It won't allow you to get to the menu screen with the computer off?
The computer must control the monitor and should have a graphics card that supports the different resolutions of the monitor which will be connected to the computer via DVI or VGA.
I think your monitor is fine, unless you cannot get it to work with your computer.
Good luck on getting your monitor to work on your computer.
Jan 02, 2011 | HP w1907 LCD Monitor
Trying to connect Lenovo IdeaCentre desktop to HP w1907, monitor keeps popping up the message like " no input signal' on VGA or DVI, DVI is always checked as default. Then going to sleep right away. Push...
wow no OS stated, nor model of Lenovo.... (so generic answers)
i guess you have no manuals on any of this. right>?
is this HP question, if the HP monitor works on other PC its ok.
so end HP worry. (my guess is HP is OK, totally) 19"LCD is OK.
leaving what, LENOVO.!! (unnamed? a stinkpad?)
this is a HP forum, so cant tell the hot key for External VGA
on any Lenovo. but you can RTM the book on it. easy.
that HP VGA monitor message means.
1 thing, the 3 video and 2 sync lines are dead.
in non geek means the VIDEO CABLE IS DEAD.
try running the PC in F8 mode this puts WINDOWS< (is it./)
in to LOW RES mode (poor) and all monitors work there.
all. (last 25 years)
if still dead, you need to use the hot key to turn on VGA, on all laptops
my HP laptop as 3 modes, VGA on , VGA off and AUTO.
nice no? that AUTO.'
The PnP wakes up the port. is that magic.
The VGA port must work, and the LCD both.
is this one of those beasts called an all-inone desk top
than name you used tells the helper nothing
as that name used for many form factors.
all in one
regular desk tops.
and more.even pocket pc.
now idea at all what you have (hp is clear on that end=)
Apr 14, 2017 | HP w1907 LCD Monitor
Monitor wont come out of sleep mode
I'm guessing you are using a the VGA input of this monitor (the smaller "D" shaped connector with 15 pins) on the back. If not, and you are using the DVI input (larger white connector), then check your PC video output. I've seen this occur with HP monitors when they accidentally get set to "digital" input. Its easy to set that way (even by mistake), but not as easy to reset to analog (VGA). To do that, you'll need to find someone with a DVI output on their video card. Once you connect to a DVI source, the monitir will come on and stay on. You then need to go into the menues of the monitor, find the setting and change it back to "analog". After you do of course, you won't get an image on your monitor until you reconnect to an "analog" (VGA) source.
Jun 02, 2010 | HP w1907 LCD Monitor
HP w1907 LCD Monitor blacks out after 1 minute
Check your monitor cable, try to reseat it (VGA / DVi port) at the back of the computer. If it still does turn off try to reseat the graphics card (if you have an expansion card) If reseating wont fix it, try this monitor to another computer and see if it still turns off. if not, then it is a problem on the video card of your computer, if yes it means your monitor is faulty.
Hope this helps.
Apr 30, 2010 | HP w1907 LCD Monitor
When I turn on my monitor, its goes straight to a
  • when you turn on computer. after sometime your monitor goes to standby mode and monitor light colour will be orange it means problem with your computer not monitor.
  • After this You Check your VGA Card.
  • When you turn on computer is there any beep.
  • After this also check your RAM.
  • May be problem with your RAM.
Try this Technique .
Mar 13, 2010 | HP w1907 LCD Monitor
HP w1907 both DVI and VGA inputs are active
hi mate, its seems by what your saying that you have both dvi and vga cables connected to the monitor from the computer, the easiest solution is to remove the unwanted input cable from the pc and monitor ( i would remove the VGA) then restart the computer you really should only run a single cable either vga or dvi not both at once the monitor just comes with both cables encase your pc doesn't have one of the connector types, there not there to both be connected at once :)
if you have a reasonto want to keep both cables connected then you need to right click your desktop , click display settings, you should see two monitors there labeled 1 and 2
click on the phantom display ( probably number 2) then click the drop down box titled "Multiple Displays" and change the option to "disconnect this display" , then apply the changes and then your problem is solved
if you are useing a older windows like 7 or 8 the proceedure is the same but the name of the drop down box may be diffrent but it still has the same option to disable the display
below is the windows screen ( i have 3 displays so ignore number 3)
Apr 19, 2017 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
477 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
