How to hook up mtx loudspeakers to cd player
Hi, I'm wondering if i need a reciever or an amp if i were to buy dual dj cd players and hook them up to MTX loudspeakers. http://www.bestbuy.com/site/olspage.jsp?...
  • Jmhndrxz Mar 25, 2008
    Sorry, the link brings you to an ad for
    MTX
    - 12" 2-Way Professional Loudspeaker
  • 807 Answers
Your link is going to a blank page.
Posted on Mar 25, 2008
  • Stuart
    Stuart Mar 25, 2008
    You will need at least an amp if there is not one built in to the CD Decks. But make sure you get one to match the speakers.
    Ask in the audio shop they should know about the maximum, rms, and peak power stuff etc.
    Mismatched speakers and amp will cause problems. Either the speakers will be overdriven by a big amp when you turn the volume up, or the speakers will put too much demand on the amp and could damage the amps power output stage. It is important.
    Hope this helps.
How do i hook up the mp3 to the cmp500
Are you asking how to hook up an external Mp3 player to your CMP deck?
Dec 02, 2014 | Gem Sound GemSound CMP500 TableTop Dual...
How do i hook up and ipod and/or computer to the Gem Sound CMP500
you need to connect the player to a dj 2 channel mixer using a red and a white RCA CABLE ...(line 1) then into (line 2) ... from pc /laptop ... need a stereo mini jack to 2 RCA (RED / WHITE) INTO back of the mixer ... before turning on please remember to set volume on pc/laptop 80% MAX ... and DISABLE EQ's or FX ... dj mixer has all the EQ / FX needed :
Mar 05, 2013 | Gem Sound CMP500 Dual CD / Mp3 / USB...
My american audio radius 3000 shows error
see if you have a reset button on the radio my kenwood was doing that its a tiny hole on the front you need a pin to reset it its that small and it works fine now
Mar 04, 2012 | American Audio Dcdpro610 Dual CD Player CD...
I just bought the cdmp - 6000 and the cd player and usb port plays the music like its a short in my speakers. Everything is new i unpluged re-hooked up everything and still the same probloem. Please help?
what do u mean it sounds like ****? it could be a dozen things cables loose wires, basically check n recheck everything n then just the dj stuff by itself that will narrow it down so we know what it is.
May 27, 2011 | Gemini Sound Products Gemini CDMP6000 Dual...
I got a mtx jackhammer 2400 watt amp. when i hooked it all up and turned it on i am just getting 12 volt on the speaker output wires and no sound. it is just compressing the speakers and that is it. any...
verify your amps input. hook up a portable cd player with a headphone to rca "y" adapter to the amp and try that, to make sure it isnt an issue with the reciever/cd deck oir the input circuit. if the amp works correctly with the protable cd player/ walkman.mp3 player whatever, instead of the car deck, then something is wrong with your decks audio output. if it does not work with a secondary input device then perhaps you have the power hooked wrong. there should be both a red and yellow power lead from the amp, the red should be connected directly to the battery, and the yellow to the "acc on" (any circuit that turns on only when the car or stereo is turned on, sometimes connected directly to the stereo). both can be connected directly to the battery, but the yellow would need a switch, in that case, to turn the amp off when not in use.
Mar 09, 2011 | Car Audio & Video
I have a pioneer djm mixer 400,I hooked it up to 2cdj mk1002. I want to run them through my pioneer reciever.which is a vsx 1020.im having a problem.IT works okay,if i run the cd player directly to cd...
If your CD player works hooked up to the DJ board, then try hooking the line out of the board into a auxiliary in or line in in or record in on your receiver using the appropriate cables.Try the CD in first and if there is too much signal then use the CD/Tape in. You need to match the output signal of your board to the input signal of your amp. Hope this helps.
Oct 22, 2010 | Pioneer DJm 400 Professional DJ Mixer
Confused
Hi jimmyjames,
How do you have the wires hooked from the sony reciever to the inputs on the mtx?
 Sounds like your Remote wire is way too big. it should be 14 guage.  It only sends a low voltage low amp signal.
Another thing that could be messing up the sounds is the routing of the wires.  you should have the power supply wires separate from the Audiop signal wiring.  Power should run down the Driver side and Audio down the passenger side.
When you answer I may be able to tell you more.
Oct 19, 2007 | Car Audio & Video
Stanton C500 Dual CD Player
hi, check that when the right side tray closes the screen must show up READ or DISC CHECK. the behaviour must be the same as the left side cd deck. if loading is faulty then the cd tray is out of alignment or sensing swithches are faulty. if disc is loading then u have a laser pickup problem or the laser ribbon cable is intermittent or the spindle motor is tired or the laser lens needs accurate cleaning. cheers.
Aug 05, 2007 | Stanton C.500 Dual CD Player
175 people viewed this question
 Grubhead
Grubhead
