Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag MDBtt60awb will not start. Power definitely at dishwasher as panel lights are on, however "start" button does nothing. Dishwasher is less than 2 years old. The panel buttons eventually turn off. I've cycled the power to the unit with no response. The door is definitely latched. Unit ran fine a few days ago.
  • 1,998 Answers
Most likely you have a bad motor when replacing the motor ihave found it is cheaper to get the pump with the motor attached where as they charge you more money for just the motor or the pump seprately try allbrands appliance parts they seem to be cheaper
Posted on Apr 30, 2010
  • Rick Ead
    Rick Ead Nov 01, 2011
    Also always make sure that the drain pump cover that screws into the sump also comes with the sump as well if it does not you would have to use the old cover off your old sump whereas units such as bosch when ordering a new sump do not come with this cover. This they do not tell you either when you order the part saves the tazmanian devil routine that I went through @#$%^ lol.
    Rick
My maytag dishwasher model MDB7749SAM stopped working about three days ago. The start/resume button flashes continuously and won't turn off. I flipped the breaker switch but nothing reset. The cancel...
Most likely moisture has affected the switches in the panel or the controller is faulty.
Refer assembly shown in the link below. Open the panel and locate the ribbon cable. Carefully take it out and with a hair dryer lightly dry up the parts. Put everything back and turn power back on. If no difference still then you may have to replace the control board.
MAYTAG Undercounter Dishwasher Control panel and latch Parts Model...
Aug 01, 2014 | Dishwashers
Maytag silverware blast not working at all. First a few buttons would not light up but I was still able to start it. now nothing works. Electricity is fine, circuit is on. It is only 16 months old. is...
I just wanted to post because I got a used Maytag from a friend and its panel wouldn't work. There is a reset button on the underneath of the dishwasher next to the power supply on a white plastic thing. I pressed it and it washes now. it puts it at a factory mode so now I need to the panel code but at least it washes.
Sep 30, 2012 | Maytag 24 in. MDB5600A Jetclean II...
By wwcon on Aug 24, 2011 We have a builtin maytag dishwasher of the "Quiet Series 200 MAYTAG Legacy Series". If we push the start/cancel on the control panel it does noet start. If we push...
Hello & Welcome to FixYa
The problem is with the control board that is bad and yes these parts are covered less than 5 to 7 years of warranty, for this you have to contact manufacturer. Please get back to me if you have any other questions.
Kevin
Sep 03, 2011 | Maytag Dishwasher
Maytag Quiet Series 300 Dishwasher not working (Model MDB5601A)
While I am not directly aware of the controls on the dishwasher I'd unplug it for a minute or two to see if the control reboots (for lack of a better term) I've seen many electroic devices that on occasion have this type of problem and simply taking the power from it may correct it.
I hope this helps,
Tom
Aug 22, 2009 | Dishwashers
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Dishwasher won't start
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Nov 01, 2008 | Maytag MDB7100AWB Dishwasher
Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Apr 13, 2007 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
818 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
