Question about Refrigerators
Water dispenser not working
I have a water dispenser inside the refrigerator not on the outside like most. it is a side by side. this happened once before and it was frozen. i don't remember how i got it working last time. nothing else in the refrigerator seems frozen like last time. any suggestions. there is a new filter and the ice dispenser is working just fine.
  • patp248 Jul 25, 2008
    Same problem. inside dispenser, ice working , not dispenser, bought a new filter.. still nothing.
I am currently experiencing the same problem. It happen when I pressed the rapid cool button on the inside of the fridge and the temperature went down to 36 degree F. I assume that my water line is frozen. As soon as we use up some of the food in the fridge, I'm going to clean out the fridge and let the temperature rise, hopefully thawing the blockage. This is the only thing that I can think of.
Posted on Jul 30, 2008
SOURCE:
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Whirlpool side by side GD27DQXFW01; ice cubes are not dispensing
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
Oct 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Door panel to dispense ice and water doesn't work. the bulk ice dispenser inside the refrigerator is working.
I have the same problem. I have to turn off the power button on refrigerator and turn it back on again. Then the ice dispenser and water dispenser will work again. It happened very often.
Oct 07, 2009 | Sub-Zero 685/S Stainless Steel Side by...
Water on floor and ice on freezer bottom
The problem is that the drain hole inside the freezer in the lower back wall is clough and the water from defrost doesn't go through that drain to the evaporative pan in the back by the compresor ,you need to clear thatdrain first meltting the ice in that hole with hot water until it goes through then once in a while (every 3,4 months put bleach into the drain to keep it clear .
Apr 22, 2009 | Frigidaire PHSC39EGS Side by Side...
There is a water leak inside the freezer
You need to remove the bottom two baskets, or more to make space. Using a hairdryer, defrost the back area. You should be able to locate a drain hole in the center below the freezer coils. This drain hole is connected on the outside to a drainpipe which has a p trap and often gets blocked up. You need to force water down the drain hole. You can use a turkey baster or similar type of plunger filled with water. Once you have cleared the blockage pour hot water till it runs freely. Hope this sorts your problem, don't forget to rate me.
Mar 11, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Water dispenser system
the dispenser in the freezer door has a small low temp heater surrounding the dispenser compartment to keep this from happening, and also to keep condensation from building up around the dispenser. this heater may have stopped working.
May 22, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
